The variable you want to use is %offlinearray this contains all devices that were found to be offline. You can also turn off the progress dialog so it truly runs in the background.
All the offline devices are stored in the %offlinearray so however you’re sending your webhook you will need to add it to the bottom of the task and use the %offlinearray variable.
You keep mentioning ‘request limits’. I googled trying to find something, but all I found was information on the old SmartThings API. What are the SmartThings request limits and timeouts if exceeded for the new SmartThings API?
I take that to mean only 12 Tasker HTML Request per minute maximum then?
Since I really don’t understand this that much, will having SmartThings connections for Alexa, Google Home and other manufacture connections affect the request limit?
How I understand it’s a maximum of 12 call per device per minute. And I don’t think that will affect any other services. I believe the limits are to each token that’s calling on the API. So Alexa should have its own same for Google and so on.
To do that we need to convert the array variable to a string, then we will replace the “,” with a Carriage Return.
First thing we will do is add a Variable Set converting the array to a string.
A9: Variable Set [
To: %offlinearray()
Max Rounding Digits: 3
Structure Output (JSON, etc): On ]
Next we will add another Variable Set.
(In the To section press the enter key on your keyboard)
A10: Variable Set [
To:
Last we will search the string and replace the “,” with the Carriage Return.
A11: Variable Search Replace [
Variable: %offlinestring
Search: ,
Replace Matches: On
Replace With: %ret ]
Then you will use the %offlinestring in your push notification.
Take a screenshot of the whole task please.
That’s weird do maths shouldn’t have been checked. It isnt on mine. Anyways good to hear that it works.
Jake could you set us up another task similar to “device health” that checks for battery levels for all devices… the task checks for battery levels at set points of 20%, 30% 40%, or etc %?
@swdeason the error on action 8 is because the variable was never assigned. Probably due to the error on action 3. Can you open up the http Request action and screenshot it.
Interesting, can you try running the task manually and let me know if it errors out again. If that’s the case you can try adding a new http Request action. Copy the URL and the body to the new action then, re-run the task and see if that clear things up.
So what is the exact end goal? Get all devices at XX% so you can send a notification? As is I have it to get the battery % of all devices with a battery. I’m just down to the displaying them the way you asked.
Would like to show any devices with 30% or less battery level.
