Hi my smartthings v2 recognizes my newly bought Fibaro smoke sensor v3.3 and motion sensorv.3.3 as Fibaro flood sensors. Any sugestions?
Maybe just a signature thing. Go into the IDE and change the device type manually.
Hi, I have similar issue with my smartthings v3, but in my case the Fibaro v3.3 flood sensor is detected as smoke sensor. Does the smartthings mess signutures ? What do you mean by go into IDE and change the device type ? Thanks for any suggestions.
Hi, did you find a solution to your problem. I have a vice versa issue just that in my case the Fibaro v3.3 flood sensor is detected as Fibaro Co sensor.
Same problem here. 3.3 flood sensor detected as smoke sensor. Manually changing it in IDE to correct device doesnt help either. It’s like it’s missing the water sensor capability.
Thanks for helping bring this to our attention and we’re working on a fix.
