# Smartthings Power Outlet Unable to work locally?
**URL:** <https://community.smartthings.com/t/smartthings-power-outlet-unable-to-work-locally/88020>\
**Category:** Devices & Integrations\
**Created:** [May 22, 2017, 4:39pm UTC](https://community.smartthings.com/t/smartthings-power-outlet-unable-to-work-locally/88020 "2017-05-22T16:39:46Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![JDRoberts](https://yyz2.discourse-cdn.com/smartthings/user_avatar/community.smartthings.com/jdroberts/32/56577_2.png) [@JDRoberts](https://community.smartthings.com/u/JDRoberts)\
**Post date:** [May 22, 2017, 5:41pm UTC](https://community.smartthings.com/t/smartthings-power-outlet-unable-to-work-locally/88020/2 "2017-05-22T17:41:38Z")
</div>
The issue isn’t the device. It’s the code, both the device type handler and the smart app.
SmartThings is primarily a cloud-based platform. With version two of the hub, they did allow for a very small amount of local processing, but it’s a very small amount. Only device type handlers which are included in the firmware for _every_ smartthings customer are eligible to run locally. And the only smart app which can run locally is the official smart lighting feature and a small amount of smart home monitor.
And that’s it. Routines don’t run locally. The mobile app on your phone cannot talk to the hub locally even if they are both on the same LAN. Any custom code, whether it’s a device type handler or a smartapp. Will not run locally.
There’s no official list of DTHs that run locally, but there’s a community FAQ:
> [@FAQ: CONFIRMED: Local Processing - Working Device Handlers](https://community.smartthings.com/t/faq-confirmed-local-processing-working-device-handlers/61875):
> Here is a list of the Device Handlers that are confirmed working with local processing (I personally tested that these show up in the “LocalDevice List”) as of Dec 8, 2017: Device Type Run Locally Execute Commands Locally Minimum HubCore Version Aeon Home Energy Meter TRUE FALSE n/a Aeon Illuminator Module TRUE FALSE n/a Aeon Key Fob TRUE FALSE n/a Aeon Minimote TRUE FALSE n/a Aeon Multisensor TRUE FALSE n/a Aeon Multisensor Gen5 TRUE FALSE n/a Aeon Outlet TRUE FALSE n/a Aeon Siren TRUE FALSE n/a Arrival Sensor TRUE FALSE n/a CentraLite Thermostat TRUE FALSE n/a Dimmer Switch TRUE FALSE n/a Fortrezz Water Valve TRUE FALSE n/a GE Link Bulb …
You can see that the SmartThings outlet _is_ there–but only if you use the stock DTH and only if you are using a smart lighting automation which only includes devices using DTHs on that list.
This isn’t what we were expecting when they said V2 would have local processing, but it’s what we got. 😥
[https://support.smartthings.com/hc/en-us/articles/209979766-Local-processing](https://support.smartthings.com/hc/en-us/articles/209979766-Local-processing)
In your case, if you use the stock device type handlers and you use the official smart lighting feature to have the pocket socket turn on and off when the switch turns on and off, it would still work locally.
[https://support.smartthings.com/hc/en-us/articles/205949776-How-to-create-lighting-automations-with-Smart-Lights](https://support.smartthings.com/hc/en-us/articles/205949776-How-to-create-lighting-automations-with-Smart-Lights)
_[View the full topic](https://community.smartthings.com/t/smartthings-power-outlet-unable-to-work-locally/88020)._
