Is there some way you can see/tell/determine that a device is using a Outlet as a repeater? I have a outside Spruce soil moisture sensor that is a good distance away from the hub. I have had trouble with it dropping from SmartThings app. I put an outlet inside the house about 3/4 of the distance to the Spruce device. Can I tell if its using the repeater ? Or do I just wait and see and if it never drops again assume?
there’s no way for us normals to to tell, but i believe support can look at the parent node for a zigbee device.
Hey @jcorbin121, I’d be happy to let you know how everything is routing! Shoot me a PM with the email address associated with your account and I can share what I’m seeing
