Same issues here as well.
CoRE fails here:
parent.onChildExitPoint(app, lastEvent, milliseconds, state.nextScheduledTime, getSummary())
And here:
parent.setVariable(name, value, false, gv)
There may be other points of failure, but it looks like either an error happening in the parent app or the child app not being allowed to run onChildExitPoint on its parent.
My point is that itâs not just what you listed. Itâs MUCH LARGER.
I agree, just trying to give ST guys a head start by pointing at where to look
All the errors I have found in apps I have code for point to parent.someMehtod() but that, and youâre right here, does not mean only parent calls are causing the error.
Yea itâs a mess. Access denied errors in shm as well, so itâs not just user saâs doing this.
org.springframework.security.access.AccessDeniedException: Access Denied
its endemic in all parent child apps
On the bright side device send events shouldnât be timing out nowâŠ, he says sarcasticlyâŠ
appear to be working again
This issue should have been resolved. Let me know if you are still seeing it.
So this is at the bottom [quote=âAaron, post:53, topic:62405, full:trueâ]
Update: there was an issue with part of the migration process that caused SmartApp permission checks to fail on the new servers. This has been taken care of and things should be running normally now. I apologize for the inconvenience.
[/quote]
Added to the Bugs: First Reports section of the community â created wiki
http://thingsthataresmart.wiki/index.php?title=Bug:_First_Reports
Hi @ady624
CoRE dashboard is giving the following error.
{âerrorâ:true,âtypeâ:âAccessDeniedâ,âmessageâ:âThis request is not authorized by the specified access tokenâ}
Iâm assuming this is all to do with the debacle that happened today.
I got standard cookie cutter replay back from SmartThing Support
Went into ide and there was no Oauth information.
Redid it.
Went into CoRE settings and reset security settings.
Still no joy.
Redid Oauth again.
Dashboard now works OK.
Wow, Iâm glad I spent the night at the GFâs house last night. On the plus side, one of the buttons on my scene controller worked on the first try, which is unusual.
Iâve been seeing this in echosistant since this morning along with the red banner saying error saving page.
Pics, or it didnât happen.
Was this update only on the NA01 shard? I didnât get a notification about the update (and I donât believe I experienced any issues). Iâm on the NA02 shard.
Yep
Thatâs must be coming from your new updates, because is nothing on line 224 that can be null on existing app. You may want to post the 224 line of code so @slagle can see where is coming from.
