Smartthings NOT Condition?
Is there any way to execute a routine if the condition added is not met? I’m trying to make an automation when my TV is not on a specific source… And i can’t select all the other sources as they don’t all show under sources.
I’m no expert on them but you could try using a virtual switch? Set that switch to OFF when you switch the TV off and set it to ON whenever you select your chosen source. You can then have a trigger for TV is ON and virtual switch is OFF to run your routine.
