SmartThings hub sth-eth200 - Welcome Code missing
Hi, @wtmolinejr
I sent you a DM with the Welcome Code and other instructions since this one appears as installed.
Please let me know if you have any questions.
Hello @nayelyz ,
I can’t find my welcome code as well, really appreciate your help! SN: 3000395604
Thank you!
Hi @Lshao
I sent you the welcome code through a DM
Hello @nayelyz ,
I can’t find my welcome code too. Please, help me! SN: 4000305176
Thank you!
Hi @Aleksei_Ivanov
Plz send me code - s/n:4000285487
Hi, @reiteravi
I sent you a DM with the code and further instructions. Please check your inbox and let me know if you have any questions
can i get a welcome code. serial number 3010149607?
Hello. I need a welcome code for sth-eth-200 with serial number 3000224236.
Hi, @Thecompdude
I sent you a DM with the code, please let us know if you have any issues.
Hello @Itati or @nayelyz ,
I accidentally excluded a Z-Wave device and had to do a factory reset. Now, ALL of my devises on the Smartthings app need to be reconnected. Can you provide a welcome code for MODEL # STH-ETH-250
SN # 3010317662
Thank you!
Hello @nayelyz or @Itati.
I also lost my welcome code for my hub. could you please help me with it? I already reset the hub (STH-ETH-200) so it should be ready to be added again.
My serial number is 3000389144 as evidenced in the photo attached.
Hi @Cwashington @jairmoreno
I sent you the welcome code through a dm
Could I add my request for a Welcome Code.
STH-ETH-200
SN# 3000215658
Hi, @MikeTV
Sorry for the delay. I see your hub was claimed today so, I’m guessing you no longer need the welcome code.
Please let us know if you still do, regardless.
Could I also get an access code for my device?
SN: 3000400824
Hi, @Alex_Jenson
I sent you the code through DM
Hi, I also need the welcome code, S/N 3000365586, thanks in advance
Hi @Al_Abalos
I reviewed your Hubs, and bouth appears as ‘CLAIMED.’ This means it is already installed on the SmartThings platform, and you won’t be able to claim it with another account. Here are some instructions to reset the Hub:
Please follow these steps:
If you are using batteries for the V2, you should remove them
Factory Reset (Using Ethernet Cable)
  1. Unplug the hub from power.
  2. Connect an Ethernet cable from the hub directly to your router.
  3. Press and hold the reset button on the hub.
  4. While still holding the reset button, plug the hub back into power.
  5. Continue holding the button for approximately 15–30 seconds.
  6. Release the button when the LED changes color (usually flashing yellow or red).
  7. Allow the hub to complete the reset and enter setup / pairing mode.
  8. Open the SmartThings app and set up the hub as a new device.
