Do you have a pointer to the rule machine repo? Or any repo that no longer exists? I did, and that broke the rest of my integration with the same issues you’ve listed. I think if you just remove the defunct repo that should fix it, although I didn’t know that at the time, so I ended up totally disconnecting and setting it up again.
You know…you are right. The timing matches. Will need to set it back up as the delete next to Bruce’s repository isn’t there.
And that fixed it! Thanks for the guidance!
my color coding doesn’t work either.yet git integration works.
I have just had this response from the support team.
**Thanks for reaching out! **
I’m going to have to disappoint you… but the GitHub integration is not yet available in the UK. We’ve got it working over on the US servers and our engineers are working on the European side. There is no ETA that can be provided at this stage. However, stay tuned to our Community for any updates!
So fellow UK users, watch this space.
We’ve been watching that space for so long our eyes are hurting.
It is slightly annoying to see that the new US shard which outwardly looks like the UK shard does have the github integration.
https://graph-na02-useast1.api.smartthings.com/
It would be really good to get an explanation on why the UK shard doesn’t have Github integration and something that has previously been answered as difficult.
If you unassociated and reassociate your account (removing any non-existing locations from your settings) it should clear up…it did for me.
Hi @MichaelS . I’m having some issues with the integration, as you can see from the screenshot the Github Repository field is now blank but yet if I got to updated it works fine. The color notification isn’t working anymore. I’m also worried you to disconnect the integration and lose all the repositories already in ST, it will be a pain trying to set all them up again and know what repo goes with that DH or SmartApp. Maybe you can help, looks like you have had some issue too at some point but Idont know if it was the same
Mine was similar. I recommend clearing all of you integration and start over with the setup…I had this occur as well. You won’t lose any of you apps. It is only the integration that appears broken in your ide.
Okay thanks I will start over the integration. It kinda suck having to re-link all the DHs and SmartApps back
The good news is that the second time I set it up it has been stable.
Thanks I will re do the integration
