SmartThings Edge support for Feibit FB56-COS02HM1.4 CO detector
I’ve adapted Mariano’s Zigbee Smoke/CO Detector Mc driver to support this device:
Manufacturer:
Feibit,co.ltd -
Model:
FB56-COS02HM1.4
The changes add its fingerprint and route it to the CO handler, accounting for trailing spaces/null characters in the device identifiers.
Tested on my Aeotec SmartThings hub:
The physical TEST button triggers “Carbon monoxide detected” in SmartThings.
A subsequent sensor notification returns the status to “Clear”.
In one test, clearing took about 21 minutes, although the audible test ended after seconds.
Alarm-status refresh works when the sensor responds.
No ppm readings: the sensor explicitly returned UNSUPPORTED_ATTRIBUTE when queried for the standard Zigbee CO measurement. The displayed battery percentage hasn’t been independently verified.
You can install this modified driver through my channel:
Feibit CO Sensor Driver invitation
Sign in, enroll your hub, and install Zigbee Smoke/CO Detector Mc from Michele Custom Drivers.
Full credit to Mariano for the original driver. This is a community modification tested on my device; the built-in test verifies reporting, not CO measurement accuracy.
Feedback from others with the same model would be welcome.
