@nayelyz,
In the stock Beta Z-Wave Switch driver there are errors in the profile assignment in fingerprints.yml of the plugs fibaro productType: 0x0602 and preferences.lua module
This device has 2 differents fingerprints in fingerprints.yml:
- id: 010F/0602/1001
deviceLabel: Fibaro Outlet
manufacturerId: 0x010F
productType: 0x0602
productId: 0x1001
deviceProfileName: metering-switch
- id: 010F/0602
productType: 0x0602
deviceProfileName: fibaro-metering-switch
- The plug with productId: 0x1001 has assigning to metering-switch profile, that has no preferences in the profile
- The plug that does not have productId has the fibaro-metering-switch profile assigned, which does have preferences in the profile
But the module preferences.lua that has the definitions of the preferences parameters only supports the productId: 0x1001
FIBARO_WALL_PLUG_EU = {
MATCHING_MATRIX = {
mfrs = 0x010F,
product_types = 0x0602,
product_ids = 0x1001
PARAMETERS = {
alwaysActive = {parameter_number = 1, size = 1},
restoreState = {parameter_number = 2, size = 1},
overloadSafety = {parameter_number = 3, size = 2},
standardPowerReports = {parameter_number = 11, size = 1},
powerReportFrequency = {parameter_number = 12, size = 2},
periodicReports = {parameter_number = 14, size = 2},
ringColorOn = {parameter_number = 41, size = 1},
ringColorOff = {parameter_number = 42, size = 1}
Therefore:
- devices that have productId: 0x1001 are paired with the profile that has not preferences and are not seen in app.
- Devices that have a productId: 0x1003, are matched with the profile that have preferences in the profile, but they don’t work because they don’t match the parameters filter, in the preferences.lua module, which only picks up the productId: 0x1001.
Solution:
Remove the fingerprint that has productId: 0x1001
or -
add productId: 0x1003 in the profile that does not have productId
And -
Add 0x1003 in the plug preferences.lua module
MATCHING_MATRIX = {
mfrs = 0x010F,
product_ids = {0x1001, 0x1003}
PARAMETERS = {
