That’s some really good detective work. And a very odd result. It would be enlightening to capture a trace of the TCP packets with tcpdump or wireshark to see what was actually being received from the device. It seems as you say to be in the underlying socket library code and maybe not in the Lua library itself.
Have you tried that alternate http library I pointed you to? Same result?
I had also found an anomaly with the Lua http library in that it sends the headers and body in two separate socket sends. Technnically, there should be nothing wrong with that, but this was enough to change the timing on the device end, which caused me all sorts of grief. And was the reason why I wasn’t getting the same result when using curl, browser, or Python code.
I hope a solution is found, but there is always a possibility that there is something in the TCP layer coming from the device itself that’s causing this.
Not sure on this since it doesn’t occur until using cosock.asyncify. It works fine when using require. It also works when making the calls locally off the hub, so I don’t think it is the device (Bond Bridge).
Not yet. Planning to try today. I may also dive into the platform tcp lua code.
Hi, @TAustin, @blueyetisoftware.
Thank you for sharing that info, I already mentioned this to the team. Once they provide their feedback, I’ll come back here.
Considering: the different statuses you saw; where the prefix was ending up; noting the effect of logging; and bearing in mind no one else seems to have noticed what is actually a rather critical bug; I am not seeing timeouts as the cause of the partial reads. To me it looks more like instead of sending
HTTP/1.1 200 OK\n
and indeed sending it with the rest of the headers and even the body, the server has actually split it into teeny, tiny chunks and sent something more like
HTTP/1.1 (with trailing space) 200 OK(with leading space) \n
The spaces could also have been separate, I just didn’t see evidence for that.
I agree on how the packets seem to be chunked. My question was spurred by @robert.masen 's comment on the pull request
I belive the passthrough for receives here is incorrectly appending the prefix argument across timeouts instead of just applying it to the whole message. I would expect that we would want to only perform that concatenation once
I’m going to end up packaging my own version of socket.http for now to get the driver running.
Ah I see. He did rather change the emphasis from the small chunks which illustrated the problem, to the timeouts which I guess could be more prevalent in practice.
Here is the workaround for anyone else that may see this. Works with asyncify on v42 and v43.
local _, code, _, status = http.request {
method = method,
url = url,
headers = headers,
source = source,
sink = sink,
-- modify receive call for prefix bug in ST tcp implementation
-- allows code prior to a fix to work with cosock asyncify
-- https://github.com/cosock/cosock/issues/26
create = function()
local sock = socket.tcp()
function sock:receive(pattern, prefix)
local data = socket.tcp.receive(self, pattern)
if prefix ~= nil and data ~= nil then
return prefix .. data
else
return data
end
end
return sock
end
