Smartthings detects every sensor wrong
Hi,
my smartthings hub which I’ve bought last week from amazon uk detects each device wrong. I’m using android.
Fibaro multi sensor:
  • detected as aeon multi sensor
  • only motion is detected
  • no temperature or tamper
Fibaro smoke detector:
  • detected as zwave sensor inactive
POPP smoke detector (zwave plus)
  • detected as door opening sensor!
Hauppauge smoke detector:
  • inactive zwave sensor
In general I don’t have configuration options for the sensors. The multi sensor shows a configuration button but I cannot tap it. Only option I can change is the device name.
Do I need to update my hub manually? I’ve even tried to include the devices manually but without success.
Ok I’ve found the website to change the device type
Hi! I have the same problem with popp smoke detector, can you please send me a link to the website where you found the solution?
