# SmartThings Current Stability?
**URL:** <https://community.smartthings.com/t/smartthings-current-stability/103832>\
**Category:** General Discussion\
**Created:** [November 2, 2017, 7:01pm UTC](https://community.smartthings.com/t/smartthings-current-stability/103832 "2017-11-02T19:01:52Z")\
**Posts on this page:** 1\
**Showing post:** 24
<div class="post-metadata">
**Author:** ![Philippe\_Portes](https://yyz2.discourse-cdn.com/smartthings/user_avatar/community.smartthings.com/philippe_portes/32/67960_2.png) [@Philippe\_Portes](https://community.smartthings.com/u/Philippe_Portes)\
**Post date:** [November 6, 2017, 6:08am UTC](https://community.smartthings.com/t/smartthings-current-stability/103832/24 "2017-11-06T06:08:27Z")
</div>
> [@lucyb](#):
> Add me to the list. My SmartThings has been stable and reliable for about a year.
Hmm… That’s also my impression but in that’s an… impression. I bought my hub kit on July 2016 and the honey moon lasted up to December 2016, after what I consider being the hub update that changed everything: sensors autonomy loss, disconnection of Z-wave/ZigBee sensors-reset cycles, etc…
I am thinking that the size of the network seems to influence a lot the performance.
So in order to be more factual, I started logging the number of time I have to reset my sensors/replace batteries for instance.
 ![st](https://global.discourse-cdn.com/smartthings/original/3X/c/b/cb52ec8f7f4c593df2fbb4a747cd083e0f173548.png)
The overall view I have:
1. Battery powered devices are more aimed to fail over time
2. Battery life decrease over time (whatever you buy Panasonic or not)
3. Multipurpose sensors are jittering Open/Close when the battery gets weak causing fake alarms. Other erratic behavior like reporting temperature but no longer reporting open/close or movement (g-sensor) are seen when battery gets weak.
4. Battery reporting doesn’t work anymore: 100% then stop working. When resetting an irresponsive sensor, the battery is found dead while this same battery was 100% or above 70% hours before.
5. Z-wave used to be very reliable before this summer. Now my Iris opener had to be reset recently. Never had to do that in 1 year. Aeotec siren lost several times.
6. Arrival sensors are not working anymore since last year X-mas hub update whatever new generation or old. (I still have some to sell back btw)
On the bright side of my setup:
1. Z-wave AC powered from GE (wall mounted switch) never failed since purchase 1 year ago
2. Zigbee bulb from OSRAM works perfectly since purchase 1 year ago
3. Home made devices based on HTTP on local network never get any disconnection or trouble (running on Arduino, Raspberry Pi, NAS).
I didn’t keep track of the numerous chats with ST support, but I guess I am in their top20 in California. I know every single guy there now. 😉
And for the record, I once tried to compute how many bugs they have per day by scraping the bug IDs sometimes shared in the forum (MOB-xxx) and not only the number was quite high, but it was not really going down over time. And that’s only for their mobile app (I guess from the MOB- prefix) so we don’t even see what is the hub side.
 ![bug](https://global.discourse-cdn.com/smartthings/original/3X/4/2/428eba3200b3dbec513c8b3f6b9ddd9f3d73faeb.png)
Anyway… I don’t know how Iris or other Ecobee are better or worse…
_[View the full topic](https://community.smartthings.com/t/smartthings-current-stability/103832)._
