It would seem like there’s an opportunity to create a generic ST to X10 gateway via HTTP using either mochad or X10 Commander though.
For those that have dedicated Windows hardware doing home automation stuff already, or that use serial port devices, X10 Commander seems like a logical choice.
For those that have Linux hardware then running mochad would work best, but hopefully with the same SmartApp that handles interfacing with the bridges.
This is Great!
I do not own a Smartthings hub yet, but I want to make sure it will work with my current X10 system before I purchase about $220 in equipment that might work…
I am running mControl v3, on a windows 7 PC, and this is with a CM15a (USB connection) connected to about 50 switches and such.
Do you have full details on how I can get the smartThings to work with a CM15a to work with X10 devices?
I see some have set up with a CM11a, and they are running Linux machines.
Do you know if I can use a windows PC to set this up, or even if I can get away without a PC?
In the meantime i moved away from mochad. I now use a Raspberry Pi, with Domoticz preinstalled, connect an rfxcom to the USB of the Raspberry and define it in Domoticz. You now will see automatically X10 devices popping up in Domoticz. It even is able to give feedback on one-way X10 devices . No with the smartapp and devices in the link below you will be able to get the devices in SmartThings. I was only using simple X10 devices, but you might want to give it a go…
I am very familiar with how X10 works, but I am new to SmartThings. I really like alot of the features offered by SmartThings and after watching your Youtube video I was convinced it would be an easy setup to the new technology, using some of the old technology until I could afford to replace it with new. One of the things I am not understanding after reviewing the SmartThings App for my phone or Ipad, is I am not able to see how to add the X10 controller for example the CM19A or the CM15A. Can you please provide further details on how this is done?
You can’t. My solution was using a bridge running Mochad software on a Linux box. However, since SmartThings to this day does not support a simple TCP socket protocol, it didn’t work well and I have scrapped this project. I gradually replaced all X10 switches with Z-Wave, which are more reliable and secure. X10 served us well, but I think it’s time for it to retire.
There was one fellow who build a Netduino based bridge to CM15A (IIRC). That would be an effective method of doing an X10 integration. There isn’t a published integration, but if you search around you might find it, and I think his code is on Github.
I recently built a Lutron RadioRA integration based on Arduino with a SmartThings ThingShield. This approach uses zigbee to communicate between the Arduino and SmartThings, and avoids the whole TCP socket mess. Arduino is a very capable platform for this type of integration between the old world, and the new.
I read somewhere here about someone integrating their Domia hub used with lightwave or ByeByeStandby products with smartthings and the post explained how X10 sockets could be controlled via Smart Things using https in an app.
Can anyone point me in the right direction?
I can’t find the post anywhere now and have a Domia hub and a smartthing hub already
I think it’s just running the app in 2x mode due to the black borders. However, to run in full screen, you can do it if the iPad is jailbroken which allows it to run a program called Fullforce. See some examples here:
Is anyone still using X10 Commander? I’ve been using it since 2010, everything has been great. I just got a new iphone and restored from a backup. X10 commander shows up on my new phone, but since it’s not in the app store anymore I can’t use it to control all my X10 stuff. Anyone have a way to fix?
Thanks. I made a post there. That app X10 commander was awesome. Used it 20 times a day. It just sucks since it still works on my old phone, but can’t get it to work on the new one since it’s not in the app store anymore. Not cool. If you have any other suggestions, let me know. I may be able to get the source info from the program but not sure who would be able to help with it.
