SmartThings Cloud is Down
I would suggest the NYCE tilt monitor they sell at lowes. Under $30. Put it on the door face inside and you know when its opened. Of course if the box is too far away…
I’m sort of on the same boat, and I repeat the same scenario every few weeks. Things are getting better then something happens and ST shoots itself in the foot, so it never gets the foothold it could have in the house.
Right now I have a few lights that I can control, my garage doors and a Schlage lock, and that’s it. It’s all “things” though… no routines, nothing fancy, and it’s a shame because I have the disposable income and the technical expertise, I just don’t feel like being bothered. :slight_smile:
I have only three apps… SharpTools, the laundry monitor and pollster. That should give you an indication as to what ST has been relegated in the house, even though I know that it has the potential to do a ton more.
Is the cloud down again, right now?
A little bit ago, I started getting network error messages from the app while trying to edit a rule in RM.
Now, when I open the app on my Android, it just keeps spinning, on the SHM/Home page.
Is anyone else experiencing this?
EDIT: I just force-closed the mobile app (i.e. just simply closing it ‘normally’ didn’t help. So, I went into System Settings/Apps/All/SmartThings and forced it from there), went back in and it all seems fine now.
So, glitch on my phone I guess. (?)
The Aeon Siren’s have a manual off switch on the bottom of them…
So far working for me…
My iphone app is stuck loading on the opening screen . eventually it displays a “failed to retrieve your account” error message, the one i’ve been getting for a week now but usually shows up much quicker.
Well now I feel dumb. I know there is a button on the front of them, but didn’t know it would silence it.
Pressing the button will turn it off, but considering that ST wasn’t entirely down, it may have kept turning back on. As a last resort, holding that button for 20 seconds will do a factory reset. Having to pair it again will be a pain, but it’s better than having the wife give it a bath.
They are pretty quiet when thrown under a nice thick couch cushion.
Hey, thnx for the Ferrari, but the car won’t start, and I can’t remotely connect to their diagnostics network because their cloud is down :stuck_out_tongue_winking_eye:
Lucky you! Every time I so much as look at mine the doors lock and the alarm goes off. The only time it will crank is at 2 am and I’m asleep… It does it by itself.
I did manage to drive it one time, sort of… The steering didn’t work and it took me to the desert. It finally ran out of gas and when I got out the car drive itself home.
I am proud to say that the geo presence works for the car… So at least I know when it leaves in the middle of the night…
I think mine is alive…
This is how I know this story is a lie.
:slight_smile:
Just do like I do, every time cloud hits the fence, I go out and buy more crap so I can be less and less dependent on the cloud and more on local processing. The problem I have is when things are going well with the cloud and I go out and buy crap dependent on it. Darn SmartThing addiction. I enjoy it too much but I cannot win! I should buy lottery tickets instead, shouldn’t I?
Ha, I’m actually still on v1. I can’t bring myself to upgrade a system that still doesn’t work. I’ve barely been able to use my app all day - it’s been taking 30-60 seconds to load each screen if it loads at all and for the past week I get a failed to access account error. I feel dumb enough for buying into the system, I just can’t buy back into it when I know it’s still bad.
Anyone thinking of jumping to Vera plus? Or already made the change?
Lots of people. Comes up weekly.
The conclusion is, there isn’t anything much better without going to custom installed 10k+ systems. Or at least there isn’t anything much more mature that ST, so going there will result in just as many headaches. Immature market is immature.
Frankly, none of the options are outstanding.
I adopted ST as it appeared to have a edge and a following, knowing I was still relatively early into IoT HA. I didn’t realize how early… but here I am. I will stay here until: 1) I am too frustrated. 2) A competitor does it right. Best Case is ST turns this around, which is what the hopeful, positive, option-less side of me says.
Like JH1 just said, nobody has made a solid unit. I thought about it and was very close to buying the veralite before buying ST but if you check amazon, they’re all rated the same. Nobody has a system that reviews better than 3.5/5 stars. So no I wouldn’t jump to vera for different headaches.
Was there any word from ST about this outage - cause, remediation, etc? Did I miss a post? I’ve been away for a bit and it has been very busy here, so I assume I overlooked it?
40 posts were split to a new topic: Cloud Talk
