[SmartThings CLI] Issue with the authentication
@nayelyz Its now working without using the PAT. Thank you for all the help.
The automation that i have is when motion detected turn on the light at 20% at 6500K
2022-07-13T18:24:38.603538130+00:00 DEBUG Zigbee Light Multifunction Mc driver device thread event handled
2022-07-13T18:25:08.612914089+00:00 DEBUG Zigbee Light Multifunction Mc driver device thread event handled
2022-07-13T18:25:29.071990432+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler capability
2022-07-13T18:25:29.178469099+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> received command: {“args”:{},“capability”:“switch”,“command”:“on”,“component”:“main”,“posit
ional_args”:{}}
2022-07-13T18:25:29.225109766+00:00 TRACE Zigbee Light Multifunction Mc Found CapabilityCommandDispatcher handler in zi
gbee_light_multifunctions
2022-07-13T18:25:29.254348432+00:00 PRINT Zigbee Light Multifunction Mc Turn On handler >>>>>>>>>>>
2022-07-13T18:25:29.260191099+00:00 PRINT Zigbee Light Multifunction Mc Turn On >>>>>>>>>>>>>>>>
2022-07-13T18:25:29.277273766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0
x0000, src_endpoint: 0x01, dest_addr: 0x0033, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody |
| < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x01 >, < On || > > >
2022-07-13T18:25:29.309079099+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:29.327222099+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler capability
2022-07-13T18:25:29.355316766+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:29.360928766+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler capability
2022-07-13T18:25:29.375864766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> received command: {“args”:{“level”:20},“capability”:“switchLevel”,“command”:“setLevel”,“com
ponent”:“main”,“positional_args”:[20]}
2022-07-13T18:25:29.392779099+00:00 TRACE Zigbee Light Multifunction Mc Found CapabilityCommandDispatcher handler in zi
2022-07-13T18:25:29.408470099+00:00 PRINT Zigbee Light Multifunction Mc handler_Level >>>>>>>>>>>>>> 20
2022-07-13T18:25:29.423274766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
x0000, src_endpoint: 0x01, dest_addr: 0x0033, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody |
| < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x04 >, < MoveToLevelWithOnOff || level: 0x32, transition_
time: 0xFFFF, options_mask: 0x00, options_override: 0x00 > > >
2022-07-13T18:25:29.459740766+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:29.483559432+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> received command: {“args”:{“temperature”:6500},“capability”:“colorTemperature”,“command”:“s
etColorTemperature”,“component”:“main”,“positional_args”:[6500]}
2022-07-13T18:25:29.490518099+00:00 TRACE Zigbee Light Multifunction Mc Found CapabilityCommandDispatcher handler in zi
2022-07-13T18:25:29.505661766+00:00 PRINT Zigbee Light Multifunction Mc handler_Color Temp >>>>>>>>>>>>>> 6500
2022-07-13T18:25:29.513068766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
| < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x04 >, < MoveToLevelWithOnOff || level: 0xFE, transition_
2022-07-13T18:25:29.600785766+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:29.617812433+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:29.626943433+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x00
33, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70,
body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x66, ZCLCommandId: 0x0A >, < ReportAt
tribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-07-13T18:25:29.660440433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:29.681911766+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:29.704873766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x77, ZCLCommandId: 0x0B >, < DefaultR
esponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2022-07-13T18:25:29.735561766+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:29.748769433+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:29.769799099+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
33, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x70, rssi: -72,
body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x78, ZCLCommandId: 0x0B >, < DefaultR
esponse || cmd: 0x04, ZclStatus: SUCCESS > > >
2022-07-13T18:25:29.801123766+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:29.807499433+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:29.821357099+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x67, ZCLCommandId: 0x0A >, < ReportAt
tribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint8, CurrentLevel: 0x32 > > > >
2022-07-13T18:25:29.838725433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:29.845079766+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:29.854939766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x79, ZCLCommandId: 0x0B >, < DefaultR
2022-07-13T18:25:29.873121766+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:29.878774433+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
er: OnOff, attribute: OnOff
2022-07-13T18:25:29.887003099+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signal
Metrics”,“component_id”:“main”,“state”:{“value”:“LQI: 120 … RSSI: -70 dBm”},“visibility”:{“displayed”:false}}
2022-07-13T18:25:29.909302766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“st
ate”:{“value”:“on”}}
2022-07-13T18:25:29.933004766+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:29.941098433+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:29.949687099+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
33, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x80, rss
i: -68, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7A, ZCLCommandId: 0x0B >, < D
efaultResponse || cmd: 0x0A, ZclStatus: SUCCESS > > >
2022-07-13T18:25:29.967647766+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:29.974794766+00:00 INFO Zigbee Light Multifunction Mc Executing ZclGlobalCommandHandler: cluster: OnOf
f, command: DefaultResponse
2022-07-13T18:25:29.981676766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
2022-07-13T18:25:30.002288433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.008525099+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:30.017270433+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
i: -68, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x68, ZCLCommandId: 0x0A >, < R
eportAttribute || < AttributeRecord || AttributeId: 0x0007, DataType: Uint16, ColorTemperatureMireds: 0x009A > > > >
2022-07-13T18:25:30.037153433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.045996433+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:30.051603766+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
er: Level, attribute: CurrentLevel
2022-07-13T18:25:30.059104766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> emitting event: {“attribute_id”:“level”,“capability_id”:“switchLevel”,“component_id”:“main”
,“state”:{“value”:20}}
2022-07-13T18:25:30.084629099+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.092364433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.099497433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.106861766+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:30.116451766+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
er: ColorControl, attribute: ColorTemperatureMireds
2022-07-13T18:25:30.123675766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> emitting event: {“attribute_id”:“colorTemperature”,“capability_id”:“colorTemperature”,“comp
onent_id”:“main”,“state”:{“value”:6500}}
2022-07-13T18:25:30.148929433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.173870433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.230632766+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:30.239488766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
33, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x80, rssi: -68,
body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x7B, ZCLCommandId: 0x01 >, < ReadAttr
ibuteResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint8, CurrentLevel: 0xFE > > >
2022-07-13T18:25:30.258469766+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:30.264077433+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
2022-07-13T18:25:30.271040100+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
,“state”:{“value”:100}}
2022-07-13T18:25:30.292434100+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.475021433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.530937100+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:30.539787433+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
33, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x74, rssi: -71,
body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x7C, ZCLCommandId: 0x01 >, < ReadAttr
2022-07-13T18:25:30.560438100+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:30.566556100+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
2022-07-13T18:25:30.577743100+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
2022-07-13T18:25:30.597823100+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.629771766+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.637455766+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:30.648689433+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x69, ZCLCommandId: 0x0A >, < ReportAt
tribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint8, CurrentLevel: 0xFE > > > >
2022-07-13T18:25:30.673735433+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:30.682702433+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
2022-07-13T18:25:30.690299766+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
2022-07-13T18:25:30.710001433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:30.717088766+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:30.727695433+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
33, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x74, rss
i: -71, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x7D, ZCLCommandId: 0x01 >, < R
eadAttributeResponse || < AttributeRecord || AttributeId: 0x0007, ZclStatus: SUCCESS, DataType: Uint16, ColorTemperature
2022-07-13T18:25:30.745913433+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:30.751617433+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
2022-07-13T18:25:30.758730433+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
onent_id”:“main”,“state”:{“value”:6494}}
2022-07-13T18:25:30.780446433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:31.324090433+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
x0000, src_endpoint: 0x01, dest_addr: 0x0033, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, < ZCLMessag
eBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0001 > >
2022-07-13T18:25:31.337821100+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
eBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > >
2022-07-13T18:25:31.359852100+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
eBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0007 > >
2022-07-13T18:25:31.385591767+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
| < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-07-13T18:25:31.409673100+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
2022-07-13T18:25:31.435419767+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:31.477547767+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:31.487014100+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
i: -68, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x01, ZCLCommandId: 0x01 >, < R
eadAttributeResponse || < AttributeRecord || AttributeId: 0x0001, ZclStatus: SUCCESS, DataType: Uint8, CurrentSaturation
: 0xFE > > > >
2022-07-13T18:25:31.524459100+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:31.530335433+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
er: ColorControl, attribute: CurrentSaturation
2022-07-13T18:25:31.537829767+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> emitting event: {“attribute_id”:“saturation”,“capability_id”:“colorControl”,“component_id”:
“main”,“state”:{“value”:100}}
2022-07-13T18:25:31.572938433+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:31.581620767+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:31.605803100+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
33, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x7C, rss
i: -69, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x02, ZCLCommandId: 0x01 >, < R
eadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint8, CurrentHue: 0x00
2022-07-13T18:25:31.628584100+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:31.635037433+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
er: ColorControl, attribute: CurrentHue
2022-07-13T18:25:31.647123433+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
d9b [0x0033] (RGBW Cozinha)> emitting event: {“attribute_id”:“hue”,“capability_id”:“colorControl”,“component_id”:“main”,
“state”:{“value”:0}}
2022-07-13T18:25:31.669625434+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:31.677783100+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:31.688259100+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
i: -69, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x03, ZCLCommandId: 0x01 >, < R
2022-07-13T18:25:31.705456100+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:31.711246100+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
2022-07-13T18:25:31.718349767+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
2022-07-13T18:25:31.740701100+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:31.746889100+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:31.757205434+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x04, ZCLCommandId: 0x01 >, < ReadAttr
ibuteResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-07-13T18:25:31.774367100+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:31.780100100+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
2022-07-13T18:25:31.787089434+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
2022-07-13T18:25:31.812263767+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
2022-07-13T18:25:31.837405100+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:31.866706767+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:31.884204100+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:31.895482434+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
33, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x7C, rssi: -69,
body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x05, ZCLCommandId: 0x01 >, < ReadAttr
2022-07-13T18:25:31.932478434+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:31.939661767+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
2022-07-13T18:25:31.946621767+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
2022-07-13T18:25:31.981712100+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:31.992917100+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:32.004775434+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
i: -69, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x06, ZCLCommandId: 0x01 >, < R
2022-07-13T18:25:32.023186767+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:32.028932434+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
2022-07-13T18:25:32.037569767+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
2022-07-13T18:25:32.059277434+00:00 DEBUG Zigbee Light Multifunction Mc RGBW Cozinha device thread event handled
2022-07-13T18:25:32.067332100+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-13T18:25:32.077819434+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
33, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x70, rss
i: -72, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x07, ZCLCommandId: 0x01 >, < R
: 0xFE > > > >
2022-07-13T18:25:32.095988767+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee
2022-07-13T18:25:32.101765100+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: clust
2022-07-13T18:25:32.108682767+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e4f05b83-5bfc-459a-812a-ae5c0f62a
It changes the level from 100 % to 20% as is supposed but then it changes back to 100% right after. So the color temperature changes and the level stays the same in the end.
@Joao_Santos @nayelyz
Let’s have how I explain what I see in the log of my Zigbee light multifunction Mc driver, although I understood that it also happened with a stock DTH for an ikea bulb.
  • As this driver has optional on-off-on transition times, it needs to save the last level value for the next power-up.
    It saves it with set_field, but in the level, color temperature and color control command handlers it first retrieves the last value with get_latest_state() and if it’s null then sends MoveToLevelWithOnOff with level 100.
  • first the level 20% command arrives and is sent to the device and emitted
  • Then the 6500°k command arrives, it tries to retrieve the last level value and get 100% or null, when it should be 20%, so it sends level 100% and it is emitted.
This worked fine and now when it goes to read the last level state it is null or 100%.
  • The color temperature it receives the 6500°k command and saves it with set_field.
    As it is zll device, the level, colorTemperatura and colorControl attributes are read 2 sec later.
Here I have to modify the driver so that it reads the attributes independently and does not repeat the reading several times. I will do in august.
Although the drivers stock do it the same, each command attribute handler reads all the attributes, onoff, level, colorTemperature or does a device:refresh()
It should work anyway because the driver always saves with set_fied the last emitted color temperature value, but it seems that sometimes it gets lost and then the next time it emits 6494°k instead of 6500°k.
The color temperature defaults save with set_fied a null value after emitting it, but in my driver I changed it to save the last value emitted to avoid this error and it worked fine and now it seems does not works well
Very odd. With the test I did yesterday, the dimmer level was set to half of what it was supposed to be, the light temperature was set correctly, but it didn’t shut off after 5 minutes.
This morning (Wednesday) I had to restart the hub, as it still hadn’t recovered the correct time following a power outage on Tuesday.
I just did another test to get some logs, and it’s working fine.
The object in question is UUID 3aca399f-1d44-4f84-ac79-6d615a4d8189 (Desk Light)
2022-07-14T03:10:48.755109734+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:10:48.765171067+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e99dcc45-da05-4a93-8826-a699cde8ad0f [0x7B8E] (Living Room Corner Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x7B8E, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xAC, rssi: -57, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x2B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-07-14T03:10:48.811731067+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:10:48.817653067+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-07-14T03:10:48.825166734+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e99dcc45-da05-4a93-8826-a699cde8ad0f [0x7B8E] (Living Room Corner Light)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 172 … RSSI: -57 dBm”},“visibility”:{“displayed”:false}}
2022-07-14T03:10:48.856580400+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: e99dcc45-da05-4a93-8826-a699cde8ad0f [0x7B8E] (Living Room Corner Light)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-07-14T03:10:48.878368067+00:00 DEBUG Zigbee Light Multifunction Mc Living Room Corner Light device thread event handled
2022-07-14T03:10:55.695495032+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:10:55.705178032+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 36ccf5b1-a330-49f9-9409-d26ae3ed4afa [0xC950] (Couch Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC950, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x98, rssi: -62, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x30, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-07-14T03:10:55.745166699+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:10:55.750738366+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-07-14T03:10:55.759229366+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 36ccf5b1-a330-49f9-9409-d26ae3ed4afa [0xC950] (Couch Light)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 152 … RSSI: -62 dBm”},“visibility”:{“displayed”:false}}
2022-07-14T03:10:55.796575366+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 36ccf5b1-a330-49f9-9409-d26ae3ed4afa [0xC950] (Couch Light)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-07-14T03:10:55.825621366+00:00 DEBUG Zigbee Light Multifunction Mc Couch Light device thread event handled
2022-07-14T03:11:07.032981367+00:00 DEBUG Zigbee Light Multifunction Mc driver device thread event handled
2022-07-14T03:11:07.079836700+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler capability
2022-07-14T03:11:07.201425367+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received command: {“args”:{},“capability”:“switch”,“command”:“on”,“component”:“main”,“positional_args”:{}}
2022-07-14T03:11:07.306367700+00:00 TRACE Zigbee Light Multifunction Mc Found CapabilityCommandDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:07.363650700+00:00 PRINT Zigbee Light Multifunction Mc Turn On handler >>>>>>>>>>>
2022-07-14T03:11:07.389526367+00:00 PRINT Zigbee Light Multifunction Mc Turn On >>>>>>>>>>>>>>>>
2022-07-14T03:11:07.436966700+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x8405, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x01 >, < On || > > >
2022-07-14T03:11:07.487817367+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:07.525241034+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler capability
2022-07-14T03:11:07.773350367+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received command: {“args”:{“level”:60},“capability”:“switchLevel”,“command”:“setLevel”,“component”:“main”,“positional_args”:[60]}
2022-07-14T03:11:07.780184700+00:00 TRACE Zigbee Light Multifunction Mc Found CapabilityCommandDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:07.817761034+00:00 PRINT Zigbee Light Multifunction Mc handler_Level >>>>>>>>>>>>>> 60
2022-07-14T03:11:07.854381367+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x8405, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x04 >, < MoveToLevelWithOnOff || level: 0x98, transition_time: 0xFFFF, options_mask: 0x00, options_override: 0x00 > > >
2022-07-14T03:11:08.015448367+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:08.026579701+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler capability
2022-07-14T03:11:08.179563701+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:08.188005367+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:08.216975701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 282766ae-f3a8-4ff5-871b-b3d65b32ade3 [0x9446] (Left Couch Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x9446, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xB0, rssi: -56, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x38, seqno: 0x49, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-07-14T03:11:08.292684367+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:08.301061701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x90, rssi: -64, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x16, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2022-07-14T03:11:08.366305367+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received command: {“args”:{“temperature”:3009},“capability”:“colorTemperature”,“command”:“setColorTemperature”,“component”:“main”,“positional_args”:[3009]}
2022-07-14T03:11:08.372754701+00:00 TRACE Zigbee Light Multifunction Mc Found CapabilityCommandDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:08.382393701+00:00 PRINT Zigbee Light Multifunction Mc handler_Color Temp >>>>>>>>>>>>>> 3009
2022-07-14T03:11:08.393344701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x8405, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x04 >, < MoveToLevelWithOnOff || level: 0x98, transition_time: 0xFFFF, options_mask: 0x00, options_override: 0x00 > > >
2022-07-14T03:11:08.485813034+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:08.498616701+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:08.508098034+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-07-14T03:11:08.514693701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 282766ae-f3a8-4ff5-871b-b3d65b32ade3 [0x9446] (Left Couch Light)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 176 … RSSI: -56 dBm”},“visibility”:{“displayed”:false}}
2022-07-14T03:11:08.559891701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 282766ae-f3a8-4ff5-871b-b3d65b32ade3 [0x9446] (Left Couch Light)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-07-14T03:11:08.605542701+00:00 DEBUG Zigbee Light Multifunction Mc Left Couch Light device thread event handled
2022-07-14T03:11:08.615234701+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:08.649333701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x38, seqno: 0x23, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-07-14T03:11:08.713138034+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:08.721048367+00:00 INFO Zigbee Light Multifunction Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2022-07-14T03:11:08.734428034+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-07-14T03:11:08.765746367+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:08.785798367+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:08.815381034+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x94, rssi: -63, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x17, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x04, ZclStatus: SUCCESS > > >
2022-07-14T03:11:08.893449367+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:08.921847034+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:08.955497367+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x94, rssi: -63, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x38, seqno: 0x24, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint8, CurrentLevel: 0x94 > > > >
2022-07-14T03:11:09.084179701+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.095932034+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:09.120325701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x94, rssi: -63, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x18, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x04, ZclStatus: SUCCESS > > >
2022-07-14T03:11:09.183603701+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:09.201150701+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-07-14T03:11:09.230259367+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 144 … RSSI: -64 dBm”},“visibility”:{“displayed”:false}}
2022-07-14T03:11:09.255338367+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-07-14T03:11:09.280876701+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.289699034+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:09.332886034+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x98, rssi: -62, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x19, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x0A, ZclStatus: SUCCESS > > >
2022-07-14T03:11:09.422701701+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.429789367+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:09.439659701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x98, rssi: -62, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x38, seqno: 0x25, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0007, DataType: Uint16, ColorTemperatureMireds: 0x014C > > > >
2022-07-14T03:11:09.477459034+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:09.482662701+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
2022-07-14T03:11:09.489188034+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“level”,“capability_id”:“switchLevel”,“component_id”:“main”,“state”:{“value”:58}}
2022-07-14T03:11:09.511131034+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.518372367+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.525724367+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.532683034+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:09.538090034+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: ColorTemperatureMireds
2022-07-14T03:11:09.544855034+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“colorTemperature”,“capability_id”:“colorTemperature”,“component_id”:“main”,“state”:{“value”:3009}}
2022-07-14T03:11:09.588278034+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.614596034+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.631261367+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:09.650476701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x94, rssi: -63, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x38, seqno: 0x26, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint8, CurrentLevel: 0x97 > > > >
2022-07-14T03:11:09.695917367+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.710590034+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:09.717971034+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
2022-07-14T03:11:09.728548367+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“level”,“capability_id”:“switchLevel”,“component_id”:“main”,“state”:{“value”:59}}
2022-07-14T03:11:09.752282701+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.775941367+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.789454034+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:09.802513367+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x90, rssi: -64, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1A, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint8, CurrentLevel: 0x97 > > > >2022-07-14T03:11:09.851970701+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:09.861845034+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x94, rssi: -63, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1B, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint8, CurrentLevel: 0x97 > > > >2022-07-14T03:11:09.899235367+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:09.904656701+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
2022-07-14T03:11:09.911196701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“level”,“capability_id”:“switchLevel”,“component_id”:“main”,“state”:{“value”:59}}
2022-07-14T03:11:09.931903701+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:09.939202701+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:09.948571367+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x94, rssi: -63, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1C, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0007, ZclStatus: SUCCESS, DataType: Uint16, ColorTemperatureMireds: 0x014C > > > >
2022-07-14T03:11:09.982338367+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:09.987509034+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
2022-07-14T03:11:09.994394701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“level”,“capability_id”:“switchLevel”,“component_id”:“main”,“state”:{“value”:59}}
2022-07-14T03:11:10.012098701+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:10.020594034+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:10.025953034+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: ColorTemperatureMireds
2022-07-14T03:11:10.032535701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“colorTemperature”,“capability_id”:“colorTemperature”,“component_id”:“main”,“state”:{“value”:3012}}
2022-07-14T03:11:10.053099701+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:13.915830035+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler capability
2022-07-14T03:11:13.955065701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received command: {“args”:{},“capability”:“refresh”,“command”:“refresh”,“component”:“main”,“positional_args”:{}}
2022-07-14T03:11:13.961889368+00:00 TRACE Zigbee Light Multifunction Mc Found CapabilityCommandDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:13.975172701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x8405, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-07-14T03:11:14.000218701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x8405, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-07-14T03:11:14.027330701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x8405, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0007 > > >
2022-07-14T03:11:14.069905701+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:14.140035701+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:14.177479701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x94, rssi: -63, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1D, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint8, CurrentLevel: 0x97 > > > >2022-07-14T03:11:14.237314701+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:14.248463035+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x90, rssi: -64, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-07-14T03:11:14.284843035+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:14.290065035+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
2022-07-14T03:11:14.296830035+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“level”,“capability_id”:“switchLevel”,“component_id”:“main”,“state”:{“value”:59}}
2022-07-14T03:11:14.319966701+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:14.326892035+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-07-14T03:11:14.336960368+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x8405, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x90, rssi: -64, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0007, ZclStatus: SUCCESS, DataType: Uint16, ColorTemperatureMireds: 0x014C > > > >
2022-07-14T03:11:14.374981035+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:14.380192035+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-07-14T03:11:14.386852035+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 144 … RSSI: -64 dBm”},“visibility”:{“displayed”:false}}
2022-07-14T03:11:14.411008701+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-07-14T03:11:14.430707368+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
2022-07-14T03:11:14.441036701+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:11:14.449409701+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: ColorTemperatureMireds
2022-07-14T03:11:14.456476368+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> emitting event: {“attribute_id”:“colorTemperature”,“capability_id”:“colorTemperature”,“component_id”:“main”,“state”:{“value”:3012}}
5 Minutes later
2022-07-14T03:16:07.185212423+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> received command: {“args”:{},“capability”:“switch”,“command”:“off”,“component”:“main”,“positional_args”:{}}
2022-07-14T03:16:07.192467756+00:00 TRACE Zigbee Light Multifunction Mc Found CapabilityCommandDispatcher handler in zigbee_light_multifunctions
2022-07-14T03:16:07.198221756+00:00 PRINT Zigbee Light Multifunction Mc Turn Off handler >>>>>>>>>>>
2022-07-14T03:16:07.205159423+00:00 WARN Zigbee Light Multifunction Mc Attempted to generate event for 3aca399f-1d44-4f84-ac79-6d615a4d8189.main but it does not support capability Color Changing
2022-07-14T03:16:07.211459090+00:00 PRINT Zigbee Light Multifunction Mc Turn OFF >>>>>>>>>>>>>>>>
2022-07-14T03:16:07.219990423+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 3aca399f-1d44-4f84-ac79-6d615a4d8189 [0x8405] (Desk Light)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x8405, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x00 >, < Off || > > >
2022-07-14T03:16:07.234613090+00:00 DEBUG Zigbee Light Multifunction Mc Desk Light device thread event handled
Hi @BlackRose67
Yes, a bit weird.
What was the level value prior to the command sent of 60%?
Is it an ikea light bulb?
I’m telling you this because some ikea bulbs, I don’t know if all of them, have a firmware transition time switch on.
This means that when you turn on a level, the bulb reaches that level progressively in a few seconds.
This means that if it is making the transition and the 60% command arrives again, which is what happens in the automation, it recalculates the transition and it may stop at a wrong level.
I tell you because in the logs I see that when it reads the level attribute it responds 58% and then 59%
I corrected this for circadian lighting by setting the ikea bulbs to transition time 0x0 instead of 0xFFFF.
--send initial values
    if device:get_manufacturer() == "IKEA of Sweden" then
    device:send(zcl_clusters.Level.commands.MoveToLevelWithOnOff(device, math.floor(newLevel/100.0 * 254), 0x0))
    else
      device:send(zcl_clusters.Level.commands.MoveToLevelWithOnOff(device, math.floor(newLevel/100.0 * 254), 0xFFFF))
    end
I will also modify it in the command handlers.
@Joao_Santos, @BlackRose67, @nayelyz, @andresg
The problem with the automations that have the level change and color temperature actions in the same rule was due to a problem in my Zigbee Light Multifunction Mc driver.
As I commented, because when setting transition times for on-off and off-on, I have to save the value of the last level before shutdown with transition time and I was managing it with the value of the last state and did not have time to save it when The second action arrived.
I have tested it and it works fine now with this version. New level and new colorTemperature are set fine in the same automation
│ Name        │ Zigbee Light Multifunction Mc        │
│ Version     │ 2022-08-04T17:59:01.724743493        │
@Joao_Santos, I did not find this problem trying with drivers that only use the stock libraries, such as the stock zigbee switch driver. I don’t know if it keeps happening to you with another driver that isn’t mine.
Hi, @Mariano_Colmenarejo
Thank you for your answer. We are glad you were able to solve it. If you guys ever notice anything similar with a stock capability please let us know.
@Mariano_Colmenarejo To be completely honest, I changed all the drivers I had to yours at the time I exposed the problem, so i don’t know if the problem persists.
But maybe its something related to ikea bulbs.
