Having real problems connecting a ST camera. My son recently purchased a hub and hasn’t had any issues connecting various sensors and bulbs. The ST camera installation seems to go well but stops at 99% and then fails. We have tried everything. Support said it was worth switching off one band of the dual band router but it is a dual band camera from what I understand.
Does anyone know of any tricks of the trade to get this working or should I just get a replacement camera?
@bluebanana Found a more recent guide to changing wifi. You reset it and re set it up. So connect it to your hotspot and see if it works. If so, reset it and try it on your main wifi. If it doesn’t work on your main Wifi, try the 5Gz band if you are trying 2.4 and 2.4 if you are trying 5. Hopefully it will work.
Update. Just as we were about to send our second camera back to Amazon it came to life and registered in the IDE. I don’t think it a coincidence that this happened immediately after the 32.7 firmware update.
