I just received a ST Button and wanted to use it to turn on a light… sounds simple enough right??
I had an Xiaomi button that worked GREAT for several months but recently it, along with all other Xiaomi motions and temp sensors, started going offline daily!
The ST button seemed to pair just fine and I set it up with the light but then I noticed that it was showing “pressed” at all times and wouldn’t work. Nothing I did would change this. I removed and re-paired to no avail…
I contacted Amazon and it was replaced with a new one (assuming the original was faulty).
I just got home and as per the instructions…
I walked over to the counter that the hub is on…
I set the button next to the hub (must be within 15 feet to pair)…
I opened the app and hit the add (+)…
I removed the battery isolator pull-tab and waited…
The button popped up and I renamed it and saved it…
I went into the devices and sure enough it shows PRESSED only!?!?!?!?!?!
Now I got to messing around a bit and I have found that apparently “pressed” means released!
If you double-hit it the status will change to “pressed twice” then revert to “pressed”
The same is true if you hold it down… shows “held” then goes back to “pressed”
Ok… so it DOES work… I went ahead and set it up to control the light and put the switch where we wanted it… it won’t work!
I kept messing with it until I found out that it will work fine only if the button is within 4 feet of the hub!!??!!
This can’t POSSIBLY be correct… can it??
Literally if the button is placed next to the hub it controls the light fine but if I back up over 4 feet from the hub it won’t work!!
I even verified that the original button works EXACTLY the same (I haven’t returned it yet).
I’m having a hard time believing this is correct…???
Input?
Suggestions?
Thanks!!
