Considering how many times thatās been asked here I think the last thing Iād call it is a stupid questionā¦
Another option is to go with LANnouncer on and Android 5.1 device (you can get a cheap $20 one from Walmart) along with a smart app called BigTalker or use CoRE. It will do exactly what you want and if you get tired of verbose notifications, it can also do a simple chime or even a warning siren sound.
There are many different ways of doing this. (Unfortunately at present Google home is not one of them.)
The first choice to make is whether you want to just use something that will play a pre-recorded sound file, in which case that sound could be a voice announcement or chime or a buzz or whatever you want, but you have to have one sound clip for each of the notifications that you want. There are devices as inexpensive as $49 that can play These kind of sound clips.
Or do you want to use a device that has ātext to speechā (TTS) capabilities. Some of the fancy speakers like Sonos can do this, and there are also some less expensive devices. In those cases, the device will speak whatever text you have defined, which gives you a little more flexibility than the sound clip method.
Once youāve decided which of those hardware options you want, then there are many different ways of setting up code in smartthings to play the alert.
Thereās a how to article in the community ā created wiki that goes over most of the options. Although the title has to do with setting up a chime, the principle is the same and the TTS options are also mentioned.
http://thingsthataresmart.wiki/index.php?title=How_to_Set_Up_a_Door_Open_Chime/Siren
Google home is actually possible but you have to run a node.js webserver on a raspberry pi or always-on PC to act as the middle man. I have this running locally in a raspberry pi and it works well.
I do these things with an android control tablet. Look up SmartTiles. I run that, and since the tablet is there I use its capabilities. I know you are a beginner, so let me take you through what I do.
SmartTiles is running on the $40 android tablet. SmartTiles is a web-based info/control screen for SmartThings. Great tool, worth the investment in learning. Thereās a newer version out with a different name.
On that tablet Iām also running an app called Tasker. Tasker allows you to automate activities on your android phone or tablet. When X condition is met, Y action occurs.
There is a Tasker plugin that bridges between SmartThings and Tasker. It is called Sharptools. It allows SmartThings events to trigger things on the phone, and it allows things on the phone to trigger events in SmartThings.
So⦠one example I have is my washing machine. Itās power usage is monitored by a smart plug. When that plug falls to zero watts, it indicates that to sharptools. Sharptools then triggers the android tablet to a) turn up media volume, b) announce ālaundry wash cycle is completeā, c) turn media volume back down.
Obviously, such things could be triggered by a door opening - so if the sensor on your back door goes to āopenā status, it would trigger your tablet to announce āback door is openā. It can get far more interesting and complex if youād like; it could, for example, announce that āopenā status every five minutes until the door closes. There are other Tasker plugins that allow all manner of things to occur. The Joao AutoApps in particular are awesome.
Wow, these are some great suggestions. Iām going to talk to the wife and get going on this stuff. Iām excited.
I have two Samsung Multiroom Audio Speakers (M3 and M5), and SHM is configured to sound the alarm through them when it detects an intrusion. This works great. Now, Iād like to find a simple way to have ST cause these speakers to sound a chime when a door sensor opens. I read the wiki on how to setup a door open chime/siren, but it focuses on providing physical speaker/chime options for actually generating sound. I donāt need physical sound generation options because I already have two Samsung speakers that ST recognizes. I just want to be able to chime them when a door opens. Any suggestions?
A simple CoRE piston will do that easily. You can even have it give you a spoken notification via TTS.
Thanks. Iāll take a stab at itā¦
Hey,
Just bought a raspberry pi. Really I have no idea what Iām doing but Iām trying to set up a node.js on it to run announcements on my google homeās locally. Do you think you could spell it out for me or send me to the appropriate place to learn how to do this?
I am new to smartthings and totally agree that it should support and integrate with google home/mini
Requirement to issue a verbal warning if for example the multi sensor is triggered Open
Multi sensor fitted to Freezer door,
Freezer door is left open
after nn minutes Multi sensor is triggered and sends an alarm message to google home
Message is played on Google home (ie Warning Freezer Door is open)
Please consider this request for inclusion in a future update.
@cpp, do you have any type of connected speaker other than Google Home? If so, you can achieve this with webCoRE. I am new too and have just set up an alert like this. It plays every 2 minutes until the door is closed properly.
I think I have a resolution but I havenāt tried it yet, if you own a Samsung S8
Enter settings and select separate app sound
Scroll to the bottom and set the smarthings app and then set the audio device to bluetooth
Whilst the bluetooth device is available it should play the notification sound through it.
I really hope this works and Iāll be looking forward to trying it
Saxnix thanks for the update I only have google home and minis as connected
speakers⦠So will keep watching to see if smartthings incorporate support
Hi, Iām having an issue with sending the notifications to Lannouncer on my Fire HD10. I can open the āThingā in my SmartThings app and send chimes to my device and it works. What I cannot do is say āWhen door opens send chimeā. How do I do that part? I feel like I am missing something really simple⦠Any help would be greatly appreciated.
Yes itās simple.
Most sounds and TTS announcements can be performed with Big Talker 2.0, RemindR, or your favorite app. Both work with TTS (Lannouncer) and speaker devices.
To get a chime code @#ALARM=CHIME rather than text
Scroll down at this link for the Lannouncer commands
http://www.keybounce.com/LANdroidHowTo/LANdroid.html
My SHM Delay app also supports tones/chimes when a door sensor opens and the Alarm is Off as part of the Delay Profile.
You are awesome, this worked! Thanks a bunch! Btw, it says on this app that you can do āask Alexaā is that having it speak through an alexa device? Is there some instructions on how to make that work?
I realise this thread is old. Isnāt it possible to use a zwave siren to do this kind of stuff? (If you only want a tone rather than spoken voice)
Sure, but the original post in the thread was about spoken phrase alerts.
As of the fall of 2018, if you live in the US or the UK hands-down the easiest way to do custom phrase alerts is just to get a $40 Amazon echo dot and use the official echo routines (not smartthings routines).
You can make the echo say anything you want it to based on a smartthings event, or play a sound file, anything from a chime to a siren to a lion roaring. Itās not as loud as a smoke alarm, but itās about as loud as a doorbell. And if you have multiple echo devices, you can choose exactly which ones you want to play the sound. And you can have different sounds for different events. Itās a really nice feature.
Hereās the FAQ for that:
