Range would be nice.
I.e. if temp between 20 and 24, or greater than 20
Could be used for anything with gradient values, like; temperature sensor, weather sensor (temp/rainfall/etc.), dimmer settings,
Nice. Definitely better than the app UI.
Unfortunately there is a disconnect between what Smarthome adopters want and what corporations want
Smartthings Vs Samsung Smartthings
It’s wierd. What you select doesn’t seem to bear any resemblance to what’s in the app!?
I am hoping that the my.smartthings web page will be the way to do everything. But mine is still in beta. There’s some super basic functionality missing yet. For instance, can’t create scenes yet.
When I created that post the forum was only showing two replies in the thread. I was a bit baffled when I saved it and suddenly a couple of hours worth suddenly appeared before it.
In the Android app things are a lot easier than they used to be. As long as the slider is to the left you can click anywhere in the widget but on the slider itself, including the space surrounding the slider. It is still a poor UI but a frustrated tap is more likely to be successful than it once was.
