My SmartThings app, in the Device view, no longer opens the device card when I tap the device icon. Now it just toggles the power for switches and plugs. Even a long press does not open the card.
I have some ThirdReality plugs that offer power metering statistics. I can only view those stats via the device card. I used to tap the device icon to open the card to view it, but now it’s just toggling the plug power. I tried stopping and restarting the app but that didn’t help.
I see there was a recent app redesign. Is there some new way to open device cards?
The basic functionality of the device tiles hasn’t changed. If an ‘action’ has been defined then tapping the icon on the tile will execute that action. Toggling between active and inactive states such as on and off is common. Short taps elsewhere on the tile open the device details. Tapping and holding gives the context menu.
Clearly the primarily purpose of the tile is to identify the device, give the status of its most essential attributes, and to act as a launch pad for the device details screen. The action icon is a useful secondary function. The previous design had a modest sized icon towards one corner of the tile which was easy enough to select if required but also easy to avoid, meaning accidental activation wasn’t a significant issue. Basically the tile did a pretty good job.
The new design has reduced the height of the tile and significantly reduced the space available to the device name. The action icon now takes up most of the right hand side of the tile with generous padding (or it does on my phones) making accidental activation when intending to open the details page much more likely. Identifying the device is now much more difficult (in my Living Room I get to see 1/2 a character of unique name). It really isn’t fit for purpose.
Just to add to the fun, a number of users have found they can’t open the details page at all for many of their devices, even if they are careful not to touch the icon.
This is the case for me: no matter where I touch the device icon box, it simple toggles the state. This has been the case for all the devices I’ve tried.
This is a significant issue - 100+ devices and cannot control dimming, cannot see power usage, cannot see anything other than whether the device is on or off. All the functionality and details once accessed by tapping the card is gone, including secondary features and history of the device - which is essential in troubleshooting or validating routines and device behavior. We just went back in time 10 years.
Oh - hub cards are affected too. Want to merge (aka “Unify”) thread networks? Too bad - can’t do that either because you have to tap the hub’s device card to do that, and the card is unresponsive.
There was a workaround posted elsewhere to remove and re-add the device. That works for a few minutes, but after a while the card that was brought back to life eventually stops working. I learned this after removing and re-adding over 20 devices, that this is only a very transient fix for a few minutes and not a real fix.
All we get is a ‘loading’ briefly some of the times that we tap a device card. @SmartThings if you are listening, please fix the app so we can see, manage and use our devices!
Same problem. I have an iPhone from work which is what I have to use. Ridiculous that I have to use an iPhone because my Samsung phone won’t operate my Samsung product
I’m going to say samsung probably really screwed this up if it’s taking them this long to fix it and they’re not taking ownership of their mistakes. They should just use a AI.
Same issue on 2 hubs. No device control for any devices added to either hub after around February of this year. It is certainly a ST issue as I can open the devices and make changes through other interfaces (Alexa, etc.). Looking for an alternative and will most likely go the Home Assistant route…
Thank you for that tip. I have been dealing with the useless bots for a month trying to get this resolved before I found it to be a global issue. The bots never bothered to give that little nugget of information, let alone a viable work-around. Thanks again!
