I have been trying to contact SmartThings support, but I keep being redirected to the community forum instead of receiving direct assistance.
We are having an issue with SmartThings API integration. We accessed the page https://account.smartthings.com/tokens to generate a Personal Access Token, selected all available permissions/scopes, but the token still does not show the smart locks connected to the SmartThings account.
The team has already checked everything on their side, and the API readings appear to be correct. Because of that, we believe the issue may be related either to the lock configuration inside SmartThings or to the token creation/permissions itself.
Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again.
Thank you for your reply.
I would like to add some additional information here. On 05/13 we configured the locks, each one under its respective address/location, and everything was correct, showing only the 4 expected locks (as shown in the first screenshot).
However, when I logged in again today, I noticed that many more locks appeared, including some with unusual update times (such as 4:04 AM), which suggests that some automatic synchronization/integration may be happening in the background.
I have not made any further changes. What we need is for the setup to remain as it appeared in the first screenshot, with each lock assigned to its correct address/location.
Access has been granted, and the email associated with the SmartThings account is:
—removed—
Here are the answers to the questions requested:
1 - Ticket number of the support case:
The last contact I had through chat had ID #3624594582
2 - Which brand and model are the locks?
We currently have 4 locks:
1 - YALE YR C/D 226/246/256
2 - YALE - model not showing on the device, only serial number: LFIEX0015U
3 - YALE - model not showing on the device, only serial number: LRIFK004EH
4 - YALE YR C/D 226/246/256
3 - If you try to perform a GET request with the specific ID of the device, do you get an error?
I will contact the company responsible for the integration to ask them this and will let you know.
For now, the information we received from them is:
“We accessed the page https://account.smartthings.com/tokens to generate a Personal Access Token, selected all available permissions, and even so, the token does not show the locks that are in the SmartThings account.
The token generated today is:
52a89b2f-d788-4180-8e6b-ef7ebd02361e
Our team has already checked our side and the API reads appear to be correct, so the issue may be related to the lock configuration or possibly the token creation itself.”
Thank you in advance for your assistance.
How the locks were integrated and organized on 05/13 and how we need them to be:
