Tap Menu, then the COG wheel at the top right, and toggle the option to ‘Use Wallpapers’ Off.
I couldn’t find an equivalent setting in the IOS app though.
OK, the app update advises when the Hub and device are on the same network it will allow faster control of devices.
And, the latest Hub firmware update advised “The SmartThings app can now communicate directly with SmartThings Hubs when the app and Hub are connected to the same local network, even when the Hub is offline.
I just tried testing it with the internet offline, and it worked for a few seconds until Android (multiple versions) advised that the Internet was no longer available. Then it just stopped working.
Oh well, at least the app appears to have local access to the Hub since it did work for a few seconds without the internet connected.
Could it be that the folks over at Samsung forgot that when Android loses internet access on the local WiFi network, it automatically switches to cellular data if internet access is available there? ![]()
Maybe they can waive the subscription fee, if that threat ever materializes, since we are all working as beta testers for Samsung now.
Every single one of my Matter (thread) device tiles will not open now. Light bulbs, water sensors, temperature sensors, power outlets, etc. all do not open when tapping on their tiles. Zwave and zigbee devices all seem to work fine. Does anyone at samsung have quality control or UI design experience?
Having same exact issue on many devices, a lot of devices do nothing when I tap on them.
Yeah, this app is junk, not well tested, and none of the hyped up features are worth it when these issues exist. I’ve rolled back to the previous version last night and disabled auto update.
I just created a new driver for an ESP bridge that talks to MySmartBlinds… it was working in the app just fine until I updated it tonight. Does this have anything to do with the plan to charge for the API?
Few things :
I used to have multi tile display for multi switch devices. Seems like this no longer supported and multi tile drop to child devices. Very disappointed. — This was sort out by new edge driver version, Multi Tile switches in dashboard work again
The 1st thing I checked is if App language in Android is supported. This feature was asked back in 2024. Still SmartThings App is NOT included in App language. I prefer my Android in my Language (Hebrew), while SmartThings App is English because of the poor translation in the lack of RTL support.
3. Another feature request to bring back the HTML support that also requested few ago is still missing. Still two lines of text limitations in details tile. Still we need to check history to see the missing lines.
ANYONE FROM SMARTTHINGS SW DEVELOPMENT. PLEASE SUPPORT YOUR USERS
Still non delivered on my devices in Holland.
EDIT: got it installed on all devices/ Miss the offline and lowbatt tiles.
On the dashboards: Only on one of four locations I see a hub button with amount. Nice to click on for offline status .
Rest is ok to me.
It’s only just reached two of my phones in the Play Store with an update date of 17th September.
Both phones were already updated by the scary Galaxy Store a couple of days apart where the update date is 21st. However there is a spurious date of the 15th on the previous release and reports of updates that left the app unchanged so it may be they cocked that up.
Other devices have not been updated from either source.
This sucks:
Two different designs of tiles and neither was disabled by Feature suggestions being off.
Sleep environment report has appeared before but it doesn’t recognise all my devices so is particularly useless to me. In its favour is that it matches the new UI.
As for the other one. That’s presumptive, intrusive, unnecessary unless ST think their own UI and info is so crap I wouldn’t know about it, and where has it come from and didn’t they get the memo about the new UI?
Same here.
I have many Matter, zigbee, and z-wave devices that do nothing when tapping the tile. On/off still works from the tile, but I can’t get into them to change anything else, like dimmer, color, etc. A lot of my devices are now useless. ![]()
Also, some devices straight up freeze the app and crash it when tapping their tiles. For instance, I have 15+ identical thirdreality zigbee water sensors, all using the same default driver. One of them crashes the app when trying to open it. Same with a ZCOMBO First Alert z-wave smoke detector. I have 8, and 1 of them crashes the app every time.
The app was always bad, but it’s now almost ecobee level bad. Jeez guys. Also I did a stupid thing of removing and readding a thirdreality zibee sensor and it’s still not letting me click on the button to open it at all. Just ridiculous.
Having the same crap with things just not opening when clicking. I noticed a few started coming back over time after reinstalling them, but get real guys. You’ve had this stuff out forever.
Crashing in general. I wonder if they bothered testhing this on Android 17 at all.
Ok I made some progress. The app is allowing me to open the button of the tilt senor but still no beeping or reaction from the device. Is the device bad?
It is beeping at the start but no reasons to motion.Calibrated and all that to on thirdreality tilt
Edit: Oddly enough it started working it seems for now, interesting. It did for a bit, now seems dead again. Nuts.
The app finally updated on the last of ‘my’ devices. I was hoping to screenshot the offline devices tile as my other devices all displayed it initially, only for it to be lost for all time if I closed it. I know I didn’t hallucinate the offline devices tile on the Home tab three times. No such luck though.
I’ve been trying to use control-only access and a highly limited range of devices on personal phones, in the hope that ST had got the hang of it by now. Although not the train wreck it was when first introduced, it still isn’t there yet. A couple of specific problems I see are:
Updated to better link the last two issues to the specific type of accounts that have them.
“Offline diagnostics tells me all my devices are online, which is true. However the settings don’t offer any of them for exclusion. Why on earth not?”
Oops I have Offline diagnostics/(three dots) settings/Excluded devices. Or didn’t I understand your problem well.
I think it is a case of my needing to format my previous post better, which I have now done.
This is an issue I only see with my member accounts that have been restricted to control of specific devices. This is currently my preferred setting for ‘personal’ accounts as there is no reason for them to need to use the app on an ‘everyday’ basis. If the app is used on one of these accounts it is usually just me diagnosing presence or tag issues. However I still expect everything that is available in the app to work properly.
In this specific case, the setting to exclude devices from the Offline diagnostics is available but it is not populated with the devices that it has access to so the devices can’t be excluded.
Like others, some devices will not open on Android even though they open on IOS.
For example, a Samsung manufacturer Motion sensor using the native SmartThings driver will open, but another exact same Samsung manufacture Motion sensor and driver combination won’t open.
Then, there’s a few native SmartThings created virtual switches that won’t open while other native SmartThings virtual switches will open.
TOO WEIRD!
And, if I tap twice on a device that won’t open I’ll sometimes see a ‘Loading…’ popup, but nothing happens.
These apps sure need a lot more baking in the Samsung labs before they give them to us!
