It seems that way. It is rather disappointing as I’d find a hub group of V2 hubs rather useful.
It also seems that you can only have one hub group per Location. That is also disappointing.
It seems to be implied that a hub group will be created automatically when you add a new (eligible) hub to a Location that already has a single hub. Hopefully it actually asks nicely first.
I normally use voice commands or my iPad OS device, but I happened to be using my Android device yesterday, and I HATE THE THERMOSTAT TEMPERATURE SLIDERS BARS. I was swiping up to get to the controls at the bottom of the new GUI, and while I was swiping, I obviously TOUCHED the SLIDER BAR and it CHANGED the temperature!!! ARRRRGGGGG!!! That’s just way too sensitive.
I don’t know if Android ever let me set the thermostat temperature to decimal values, but at least I can still set the thermostat temperature to decimal values on the iOS app.
Ever since the update, the Humidity and Battery level data does not update. I have 2 - CT-100 thermostats… same for both.
Has anyone else experienced anything similar and found a solution. Support is useless…
Also, I 1000% agree the design is horrible. Several times I have inadvertently raised the temperature settings by 10+ degrees just by scrolling down the page…
The initial documentation I read was that Samsung TV with dongle is supported. Later learned as I was trying to create a hub group, that it cannot be used.
They’ve fixed it, at least in the Android app. App version is the same though so it’s a change in the webview, now by default it’s in compact form and you can extend it if you want with the small icon with bars.
