Since yesterday my Zigbee smart switches are crazy.
I needed to remove 2 and reconfigure, but now I am not able to include them.
I did remove both from Smartthings app, and they don´t come back when I try to include again. And I am not able to remove them from API, with error like:
Hibernate operation: could not update: [physicalgraph.device.Device#xxxxxx-56a7-438c-822c-xxxxxxx]; uncategorized SQLException for SQL [update device set version=?, completed_setup=?, component_label=?, component_name=?, date_created=?, device_network_id=?, error_state=?, firmware_version_id=?, group_id=?, handler_version=?, hub_id=?, is_component=?, join_fingerprint_id=?, label=?, last_updated=?, location_id=?, name=?, parent_device_id=?, parent_smart_app_id=?, previous_handler=?, previous_zigbee_id=?, primary_tile_name=?, profile_id=?, profile_type=?, protocol_connection=?, raw_description=?, sort_order=?, type_id=?, virtual_smart_app_id=?, zigbee_id=? where id=? and version=?]; SQL state [25S03]; error code [0]; (conn=4734834) Communications link failure with primary host na04useast2-datamgmt.cluster-cwcarkwvvr9r.us-east-2.rds.amazonaws.com:3310. Connection timed out; nested exception is java.sql.SQLException: (conn=4734834) Communications link failure with primary host na04useast2-datamgmt.cluster-cwcarkwvvr9r.us-east-2.rds.amazonaws.com:3310. Connection timed outCommunications link failure with primary host na04useast2-datamgmt.cluster-cwcarkwvvr9r.us-east-2.rds.amazonaws.com:3310. Connection timed out
Today at morning Alexa sent me many messages that these switches were included… close to 12 hours after I did try the command.
I believe that some AWS Amazon servers used by Smartthings are not working fine.
Any change in Samsung Smartthings infraestructure?
