Smartthings and Nethome Plus
I just purchased an Blue Ridge mini split for my home. It is wifi enabled and compatible with Google Home and Alexa. I’ve integrated it with Google Home, however, I’d like to see about integrating it with Smartthings, as well. Are there any plans to add Nethome Plus to the list of Smartthings compatible devices?
As of mid 2019, smartthings has published their API and it is now up to the individual device manufacturers to create and maintain their own integration. So you should talk to the device manufacturer and let them know that you would like to see it happen. :sunglasses:
https://smartthings.developer.samsung.com/
I am extremely interested in doing the same thing. Did anyone find away to do this or some work around
Best I found was to set the mini split up on SmartLife.
It’s not 100% functional, but it’s enough for what I needed, which was to turn the temperature down when the center living room light turns off via IFTTT.
It looks life smart life requires a monthly subscription? Is this true?
