Smartthings 09/2026 app update breaking devices GUIs
The recent app update has caused problems. Several of my devices will not display their GUIs when I select them. I am not able to control brightness or color on my Orion light bulbs, I can not control individual channels on my Zooz power strips, and I can not see the detail data from my Ikea Alpstuga air quality sensor.
These devices cover several interfaces, Zwave, wifi, & matter. There may be others.
I have not been able to find any Discourse page focusing on new versions and issue reporting.
I am having the same issue. My issue is with the IKEA Alpsturga air quality sensor (matter) and eve energy smart plugs (matter and wifi). Also all my Onvis Smartplugs (matter) are kaput. I have other matter devices (smart wings shades) that work fine. Both devices are still running and routines are using them correctly. Both devices can be opened in https://my.smartthings.com/ it is only in my Android App that the issue presents. I’ve done a full uninstall of cache and app and files of the app and reinstall. Pixel 10 proxl fully updated. Still no luck.
When I say broken gui I mean I can’t “tap” the device in ST to open it.
It does seem to be all matter devices to some extent.
I have the same issue on multiple devices including a Sengled dimmable zigbee bulb, and all locally controlled Kasa wifi devices,
@douglewellen78 can you use the web interface (link in my post) to see the devices?
Here’s a good one… my wife tells alexa to.dim the living room lights and it did, but it also turned on the dining room lights and dimmed evey other light that was on. Couldn’t even open the cards in the app to fix it and had to use voice. Such a shitty update, but ill say one thing, this site is getting more quiet by the day. Samsung better rememebr they aren’t apple.
I can. Every device that I cannot open in the app can be opened in my.smartthings.com
Yes, my.smartthings.com does allow me to control the Zooz power strip, the Orion light bubs, and displays the data from the Ikea air quality monitor.
It appears I’m not the only one with this issue. And it also appears to be tied to the app update. Does someone from Samsung see these posts and reacts? Or is there another mechanism?
It is possible ST looks at these posts but don’t expect a response. You can send reports to ST using the app by tapping on Menu and selecting Contact us. You may also posts comments on the app store where they are more likely to view comments.
I hadn’t encountered anything like it until this afternoon. I’d added a number of devices to a control only account and found I couldn’t open the device details page on a number of the extra devices. Unlike many others, I was able to clear the problem by powering off my phone.
Given that device names are now so heavily trucated that those of us who include room names are lucky to even see half a character of unique information, the device details can be the only way of identifying the device. That or accidentally hitting the now massive and intrusive action icon and hoping you can see what it did.
OK, I just sent an error report from the app? Has anyone else? It seems like it would get more attention if they understood it was a more widespread problem.
I put in a ticket and they sent me this below. None their troubleshooting fixed it. I also sent them this thread link. Most of my devices work fine. I even have two identical Meross smart plugs. One works and one does not.
My name is Lee Mauren from Samsung SmartThings Support.
I understand how frustrating it can be when your devices appear in SmartThings but you are unable to open their details or access their controls. I appreciate you taking the time to report the issue and provide log information to assist with the investigation.
Based on the information provided, multiple devices, including your Meross MSS115 smart plug, appear in the SmartThings app but cannot be opened or controlled. Since the devices are visible within the SmartThings app and the issue affects the application interface rather than the device onboarding process, this concern falls within the scope of SmartThings Support.
To help isolate the issue, could you please provide the following information:
  1. Does this occur with all devices in your SmartThings location or only specific devices?
  2. Are you receiving an error message when tapping the device tile, or does the device details page simply fail to load?
  3. Have you recently changed locations, Samsung accounts, or SmartThings Hub settings?
  4. Are other household members experiencing the same issue when using SmartThings?
In the meantime, please try the following troubleshooting steps:
Step 1: Refresh the SmartThings App
  1. Close the SmartThings app completely.
  2. Open your phone’s Settings.
  3. Navigate to Apps > SmartThings.
  4. Select Force Stop.
  5. Reopen the SmartThings app and test the affected devices.
Step 2: Sign Out and Back In
  1. Open the SmartThings app.
  2. Tap Menu.
  3. Tap Settings.
  4. Sign out of your Samsung account.
  5. Sign back in and test whether device details can be opened.
Step 3: Verify SmartThings App Version
Please ensure the SmartThings app is updated to the latest version available through the Google Play Store.
Step 4: Clear SmartThings App Cache (Android)
  1. Open Settings.
  2. Tap Apps.
  3. Select SmartThings.
  4. Tap Storage.
  5. Select Clear Cache.
  6. Relaunch the application and test again.
Step 5: Test Another Network
If possible:
  1. Switch between Wi-Fi and mobile data.
  2. Open SmartThings.
  3. Attempt to access the affected devices again.
Advanced Troubleshooting
If the issue continues:
  1. Remove and reinstall the SmartThings app.
  2. Log back into your Samsung account.
  3. Allow all requested permissions, including Location and Nearby Devices.
  4. Verify whether device details pages open correctly after reinstalling.
Submit an Error Report
If the problem persists, please submit an error report immediately after reproducing the issue:
  2. Tap Menu.
  3. Select Settings.
  4. Tap Contact Us.
  5. Select Error Reports.
  6. Choose the affected device or category.
  7. Enter a description of the issue.
  8. Ensure Send System Log Data is checked.
  9. Tap Send.
Thank you for contacting Samsung SmartThings Support. We appreciate the time you’ve taken to work through these troubleshooting steps with us. Once we receive your update, I will be happy to continue assisting you and work toward resolving your SmartThings concern.
I also got a response, but I had already cleared cache, data and uninstalled the app. Here’s my email. There was nothing here that changed anything.
I understand how frustrating it can be when your devices remain controllable through SmartThings, but their full device detail pages no longer load, especially when the issue affects multiple device types and began after a recent app update. I appreciate the detailed information you have provided, including the affected devices, SmartThings app version, and application logs.
Based on your description, this appears to be related to the SmartThings application rather than device connectivity. Although the affected devices include Matter, Z-Wave, and Wi‑Fi devices, you are still able to control them through my.smartthings.com, which indicates that the devices themselves remain connected and responsive. The issue appears to be isolated to the SmartThings mobile app, specifically the device details page, presentation layer, or user interface rendering.
To help us better understand the behavior, could you please confirm the following:
  1. Does the issue affect all devices or only specific devices?
  2. Are other members of the SmartThings location experiencing the same behavior?
  3. Does the issue occur on another mobile device signed into the same Samsung account?
I understand that you have already:
  • Cleared app cache and data.
  • Uninstalled and reinstalled SmartThings.
  • Confirmed devices remain accessible through my.smartthings.com.
Thank you for performing those steps.
Additional Troubleshooting
Step 1: Verify SmartThings Labs Features
  2. Select Menu.
  3. Tap Settings.
  4. Select SmartThings Labs.
  5. Disable any enabled experimental features.
  6. Restart the SmartThings app and test the affected devices.
Step 2: Verify Device Location
  1. Open SmartThings.
  2. Confirm the affected devices are assigned to the correct Location and Room.
  3. Test opening the device from both the Room view and the Devices tab.
Step 3: Test Another Network
  1. Connect the phone to a different Wi‑Fi network or mobile data.
  2. Restart SmartThings.
  3. Test opening the device details page.
Step 4: Verify App Permissions
  1. Open Settings > Apps > SmartThings > Permissions.
  2. Confirm Location and Nearby Devices permissions are enabled.
  3. Relaunch SmartThings and test again.
If available, please test using another Android or iOS device signed into the same Samsung account. This will help determine whether the issue is account-related or device-specific.
Since logs were already provided and the issue appears persistent, we recommend submitting a fresh error report immediately after reproducing the issue:
  2. Tap Menu.
  3. Select Settings.
  4. Tap Contact Us.
  6. Choose the affected device category.
  7. Include the following details:
    • Device details pages do not load.
    • Device controls on the room page continue working.
    • Issue started after the September 2026 SmartThings update.
  9. Tap Send.
My Zooz actuator stopped working but not just the details screen, it would not function at all after the update. The Smartthings app reported the valve closed even though it was open. I responded to the support ticket but have not heard back from them. I finally removed the Zooz actuator and added it back. The details screen still does not work, but it does at least respond to open/close and does report the correct status(open).
I’m not getting a warm and fuzzy feeling from tech support. They respond as if I just need to diagnose what is wrong and/or reinstall things, as opposed to them just not releasing an update that breaks things in the first place. I keep getting closer to ditching Smartthings and going with Hubitat because of things like this that have occurred over the past year.
I haven’t heard back since my last reply. I had a “to-do” item to build a Home Assistant server after Christmas. That’s looking more and more like a higher priority item.
I’m trying another ticket. I have a zooz zwave valve, meross matter plug, sonoff zigbee button, a offline switch and a virtual switch that have the same issue. We’ll see how they respond.
So samsung, just gonna let this stay broken. Are you kidding me?
Wow. I replied to both emails/tickets they sent me with the requested info. Both bounced back the next day saying undeliverable.
I just looked at the bottom of the email that they send.
Just did my third ticket asking them how am I supposed to send the info they requested. There are no other links on the email.
My tablet has the exact same issues so it must be a Android app issue. The same devices are normal on the Smartthings dashboard.
They want you to send everything through the app.
