Could someone explain the readings in the right hand box on the multi Sensor app.
I’ve got readings of: -xx,xxxx,xx
I don’t know what this means. I’d guess xxxx is pressure and xx is humidity percentage. But couldn’t guess at -xx is
Can someone confirm please. Thanks in advance
ma10
October 26, 2015, 11:57am
#2
That should be orientation readings of the device. Also, where are you reading the reading “1025” as I didn’t think the multi sensor did pressure readings?
http://support-uk.smartthings.com/hc/en-gb/articles/204778611-Samsung-SmartThings-Multi-Sensor
It’s the x,y,z output from the three axis accelerometer sensor.
