skycris
(Ayden)
August 8, 2024, 6:07pm
1
I am trying to call smartthings CLI to switch channel. I believe I followed the example well.
smartthings devices:commands XXXXX 'tvChannel:setTvChannel(1)'
But this returns this error.
AxiosError: Request failed with status code 422:
{“requestId”:“2260968512939144970”,“error”:{“code”:“ConstraintViolationError”,“message”:“The request is
malformed.”,“details”:[{“code”:“UnprocessableEntityError”,“target”:“commands[0].arguments[0]”,“message”:“commands[0].arguments[0]:
integer found, string expected”,“details”: }]}}
Code: ERR_BAD_REQUEST
I believe I followed the example well described here (GitHub - SmartThingsCommunity/smartthings-cli: Command-line Interface for the SmartThings APIs. ).
# capability and command with an argument (note: single quote command arg to prevent specific shell parsing errors)
$ smartthings devices:commands 00000000-0000-0000-0000-000000000000 'switchLevel:setLevel(50)'
Please let me know what is the write format to call this CLI with arguent.
skycris:
In the example you followed, the argument to setLevel is an integer. For the setTvChannel, the argument is a string and must be quoted.
1 setLevel(level<integer>, [rate<integer>])
2 setTvChannel(tvChannel<string>)
bep@debian12:~$ smartthings devices:commands xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxx 'tvChannel:setTvChannel("20")'
Command executed successfully
skycris
(Ayden)
August 8, 2024, 6:45pm
3
Thank you so much. It works!
