I hope someone might be able to assist me, please. I am working with the SmartThings branded CentaLite 3305-S. I am using this device in my freezer to monitor 1)Temps 2) if the door opens. The signal if fine and the device is functioning, but the unit is reporting anything with a 1 degree change. Unfortunately, in the deep south, in the dead of summer, its hot. So the unit is changing temps a lot. So in turn, the battery went from 100% to 33% in 24 hours. I need to increase the change value to maybe 5 degrees.
I am not new to IDE and custom DH’s, but mostly a copy/paste ninja. So I havent been able to find a solution to this. I am pretty sure that I need to add a EnrollResponse, but not sure. I am currently using the SmartThings DH Here
the square motion sensor (gen1) that uses CR123A? or what model + battery? If it’s a model with coin cell then I would write it off - terrible life. I don’t think the frequent temperature updates are the problem.
I don’t have any advice on editing the device type, but it seems like a misapplication for motion sensor, these are pretty sensitive and you are operating in a breezy environment.
I use the Smartsense gen1 (device log says centralite model 3300-S) open/close sensor using CR2 . for the freezer door and temperature - battery life more than a year. I have not noticed that 1 degree reporting has decreased battery life significantly. My temps log looks like yours, every 5 minutes while cooling.
It’s the temperature killing your battery. I’ve been using the SmartThings Multi Sensors in my freezers, and the CR2450’s that powers them can only survive a few days at that temperature. I had to get an external AA battery pack and solder it on, which isn’t the cleanest solution.
If some manufacturer came out with a temperature monitor specifically designed for freezers, I’d buy it instantly.
I honestly think there are methods to change reporting frequency that would improve the battery, I just cant write this code from scratch and cant find any good examples. For example.
The Smartthings Zigbee method “zigbee.temperatureconfig” - Looks like it can change the Min/Max reporting.Maybe it has other parameter as well, but I cant find the documentation.
The zigbee.configureReporting has a reportableChange parameter and you can change the %orDegreee change needed for an update (this device defaults a 1 degree), but I don’t know how to use this.
@bartdyer Get an Iris open/close sensor. It’s better for use cases like this. I have three freezers with the Iris sensors in them. I’m going on a year without any issues.
I’m also in the South, perhaps not the deep South, but I still see temp readings every few minutes.
def temperatureConfig(minReportTime=30, maxReportTime=3600, reportableChange=0x0064) {
configureReporting(TEMPERATURE_MEASUREMENT_CLUSTER, 0x0000, DataType.INT16, minReportTime, maxReportTime, reportableChange)
//attribute type 0x29. Read 6400 as 0064 -> 100 (decimal). Reporting if the value changes by 100 -> 1 deg C
For example, if you want it to report every 6 hours you could do this:
