“One of the great features of these controllable outlets is that they can sense if someone is trying to manually turn the light on at the lamp, and even if the outlet is off, it will turn on in response. Give it a try.”
If I read this correctly, if someone uses the switch on the actual lamp itself, the SmartOutlet will detect that physical action and turn on power?
If this is true, why isn’t that mentioned on the product page? That seems to be a pretty great feature.
oops! Thats only for the Centralite Lamp module right now, not the Centralite Appliance (SmartPower Outlet) I removed that paragraph from the support page.
So, is there a module that would also have dimming capability out there? I was rereading some older posts and I saw you mentioned lamp module vs appliance (I assume that is dimming vs non-dimming). Can I purchase that Centralite Lamp module? Is that this?
Any update on when the lamp module will be available? It is available under the PEQ brand (https://www.mypeq.com/shop/lamp-module.html). Will that work with the SmartThings hub?
