Been searching the web for this one and can’t find a solution .
When I connect Smarthings to my Harmony - the harmony can’t read the state of my KASA outlets - it says no connection, or unable to retrieve state - in the devices section you can toggle it and it works despite it saying it can’t read the state - that would be OK except within “Activities” unless it can read the state of the switch, you are prevented from using it - for example killing the power to an outlet via smarthings.
I’d recommend using the Smartthings integration for Kasa plugs. By eliminating the second arms length control/state check you will have a much more reliable and responsive automation experience.
Thanks. I was hoping to use my Harmony remote to trigger a power state change on an outlet - yes I can go direct from Smarthings - but defeats the “Action” I was hoping to create with the Harmony Remote.
Hi, I am also trying to control Kasa Plugs through the Harmony remote. I can control them with the Kasa App or the Smartthings App but after adding Smatthings Device under Home control on the Harmony Hub/remote the devices are listed but say No connection. If a device is selected a window pops up with cannot connect to “Plug 1” Ensure bridge is properly connected. It’s powered on, and try again. I’ve reset both hubs deleted and added the smartthings as a device in the harmony app and checked that all the devices show connected when I log into my router. Any Ideas are welcome. I added the Kasa plugs and want to add new Kasa switches to replace ancient X10 plugs and switches that I can control with the Harmony remote.
I know it’s not ideal but you should be able to create a Virtual Switch and use SmartLighting to mirror the state of the VS and the Plug and use the VS in the Harmony Activity…
I’m also interested to know what app you’re referring to. I still have access to add Smartthings from the harmony app. I just removed it and added it trying to fix the issue. A user in the Harmony community posted he also has a problem with the Kasa plugs intermittently, not all the time. I think the programming in Smartlights is a little beyond my expertise. Thanks for the input.
