Smarthing api authorize device
Hi trying to authorize my samsung washer to be able to get minutes etc using this github script: https://github.com/bradymholt/smartthings-rest-api
Using the api here: https://graph-eu01-euwest1.api.smartthings.com
I can’t select my device here any ideas?
And I can see my device on the device tab.
Does the browser console indicate an error? I tried to reproduce and the device list loaded as expected.
I don’t think so, I have a friend with the same washer trying to do the same here. Same for him. I also thought it could be a browser error, but i tried firefox, internet explorer, google chrome. Also on mac/windows 10. No luck.
I think that samsung needs to take a look on this bug. Or can somebody guide me how I can read status from the api via curl etc ?
https://smartthings.developer.samsung.com/docs/api-ref/st-api.html#operation/getDeviceStatus
curl -H ‘Authorization: Bearer {personal access token}’ -X GET https://api.smartthings.com/v1/devices/{deviceId}/status
Can I use this without device authorizations ?
And can i call this api from anywhere? I do not own a smarthings-hub.
You do not need a SmartThings hub to leverage the API. You will just need a personal access token with device scopes - https://smartthings.developer.samsung.com/docs/auth-and-permissions.html#Personal-access-tokens
Thank you it worked now!
