I thought I would copy what I posted in another smartcam thread regarding getting smartcams to act as a motion sensor for SHM. It uses IFTTT so a slight delay but it is working for my needs so far. I considered Arlo Pro 2 but for $800 and 4 cameras the smartcam seems like a better deal. got 5 for $300 refurbished on amazon.
Jason
I just ordered 5 of these cameras and was disappointed that there isn’t integration on motion to SHM. I am just getting started with SHM so not sure how I am going to use the motion with all the cats in my house but may put a couple cameras in covered locations outside.
In order to get this to work here is what I did.
created a gmail account for the camera (will need to do this for each camera)
created an ifttt account for the camera
created an applet to turn on a switch when email sent on motion
now for the switch. I created a custom ‘simulated motion sensor’ that is also a ‘switch’ when the switch is turned on in turns on motion then immediately turns off the switch and motion. Thus creating a ‘pulse’ of motion.
Since I don’t have full SHM set up yet I used a custom rule to give me a push notification on motion through SHM. I verified that when a clip is stored on the camera due to motion all the dots get connected and the notification fired a few seconds l later.
I think this is usable for my purposes. Here is the device handler for the motion/switch. I would enjoy some feedback if this is useful for others or not.
Jason
Copyright 2014 SmartThings
Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
for the specific language governing permissions and limitations under the License.
metadata {
// Automatically generated. Make future change here.
definition (name: “SmartCam Motion Sensor”, namespace: “smartthings/testing”, author: “Jason”) {
capability "Motion Sensor"
capability "Switch"
capability "Relay Switch"
command "active"
command "inactive"
command "onPhysical"
command “offPhysical”
simulator {
status “active”: "motion:active"
status “inactive”: “motion:inactive”
tiles {
standardTile(“motion”, “device.motion”, width: 2, height: 2) {
state(“inactive”, label:‘no motion’, icon:“st.motion.motion.inactive”, backgroundColor:"#ffffff", action: “active”)
state(“active”, label:‘motion’, icon:“st.motion.motion.active”, backgroundColor:"#53a7c0", action: “inactive”)
standardTile(“on”, “device.switch”, decoration: “flat”) {
state “default”, label: ‘test motion’, action: “onPhysical”, backgroundColor: “#ffffff”
main "motion"
details (["motion","on"])
def pair = description.split(":")
createEvent(name: pair[0].trim(), value: pair[1].trim())
def active() {
log.trace "active()"
sendEvent(name: “motion”, value: “active”)
def inactive() {
log.trace "inactive()"
sendEvent(name: “motion”, value: “inactive”)
def on() {
log.trace "$version on()"
off()
def off() {
log.trace "$version off()"
def onPhysical() {
log.trace "$version onPhysical()"
offPhysical()
def offPhysical() {
log.trace "$version offPhysical()"
