I would like to use an Aeon metering switch to turn on automatically upon power being applied. Is there an app that can see the device become active on the network (it will have already been included) or use the metering value to switch on? I have tested an app to turn on a switch when the power draw reaches (X). The problem is, this is designed for a combination of two switches not the same one. Also, I am not sure if the Aeon switch meters it’s standby power or would it be enough to hit the minimum trigger value?
