Any chance the app can be fixed. Not only do I have to go past the annoying Bluetooth bubble I now get presented with the Legal Information screen every single time I open the app. Nine times out of Ten it says there is a network error and the up is completely unusable. Please fix both issues!
Hi AverageJoe90,
Iām not sure if your situation is similar to mine, but Iāve just had and fixed (fingers crossed) an almost identical issue.
Iām running the latest SmartThings app on a iOS 14.0.
- A random time period after opening the app (Version 1.6.51-435), this can be anything from 1 to 60 seconds, I am presented with a grey screen entitled āLegal Informationā. If I manage to click on a menu or a button before this page appears it seems to delay the āLegal Informationā screen being shown, but only temporarily.
- There is some text and a link to view the āPrivacy Policyā, which opens another page and a button in the top right labelled āDoneā. The āDoneā button appears to be the only way to exit the āLegal Informationā page, but pressing it just causes a dialog box to appear. The dialog states there has been a network error, āA network or server error has occurred. Try again laterā and just an Ok button to dismiss the dialog.
- Pressing the Ok button just takes me back to the āPrivacy Policyā page.
- Restarting the app is the only way to get out of this.
Iāve attempted the following to resolve the issue:
- Signed out and signed back in.
- Rebooted the phone.
- Uninstalled and re-installed the app.
- Turned off WiFi connection and attempted all the above on 4G connection.
None of these actions have resulted in the issue being resolved.
At this point the app is effectively useless.
However I remembered that yesterday I enabled GitHub integration within the SmartThings IDE to allow me to add some custom Device Handlers. So Iāve went back and deactivated the integration:
- From main page of the IDE, goto settings,
- Click the link entitled disconnect, just under āDefault Namespaceā.
- Follow the instructions
- Restarted the app and the problem is resolved, no instances of grey / legal information screen since.
Hopefully this will help someone else.
In my case I have not made any new or changed any GitHub connections lately.
https://community.smartthings.com/t/hub-firmware-release-notes-0-32-7/205527/29?u=nezmo
Same here - now i canāt even agree to the legal terms bc it just says network error
SmartThings app on iphone iOS 13.6.1 opens to Legal Information Agreement - when you tick the āI Agreeā box and tap Done it gives the error: Network Error "A network or server error occurred. Try again later. Iām assuming this is due to the rollout and changes made.
when are they going to just open up a local network administration method by IP or something - this is ridiculousā¦ I was happy for a second bc the email clearly states thatās what this update was for
Which email was that?
Some people reported they were seeing this message if they were linked to GitHub, but if they unlinked from GitHub the message went away.
Just started getting this myself. Not sure itās hub FW related as my hub has not updated yet.
But yeah, my ST app on my iPhone and iPad is now useless.
@Brad_ST @blake.arnold @Kianoosh_Karami - I think this needs some priority attention.
UPDATE: A restart of the apps on my devices appears to have cleared this, for now.
Seriously, this is a real mess lately. I just cannot rely on it at all right now.
Not linked to Github
What a mess.
Online / offline status for Hub Connected devices will be monitored and generated locally. Iām assuming this means we can monitor it ourselves locally? If not - what does it really matter? lol
It might matter a great deal because there have been continual problems with device health since it was first introduced, most specifically devices being marked āoff-lineā which actually werenāt. This in turn could limit the automations that would use that device.
There has long been speculation that much of this was probably due to cloud latency.
So the hope is that if device status is moved to the hub where possible, it will become much more reliable, and that in turn will improve the reliability of automations that trigger off of device status.
Iāve done a restart of the ST app on the iPhone, a soft reboot of the phone, a hard reboot of the phone, a test using cellular data only - no response, restarted the main hub, restarted all 3 hubs and the modem, reinstalled ST, made sure it wasnāt running on any other mobile device, and checked to make sure nothing was linked with GitHub ā¦ iām dead in the water
** UPDATE ** - The app is randomly working now - without going through any of those steps again.
Posts were moved from Hub Firmware Release Notes - 0.32.7 as there is no connection between the hub firmware update and this issue.
There appears to be degraded performance from the service that handles content such as the privacy policy. The responsible teams are aware and looking into it.
Thank you.
It would appear to have resolved itself now. Still get the bluetooth everytime, still very annoying
This same issue is now back again. When opening the ST app this morning, I get the legal information screen after some seconds. Tapping the āagreeā button results in the error message that is mentioned earlier. Tried everything to get rid of this. Even installed the app on another phone to check, and after logging in with a brand new created Samsung account the same thing happened. So app is useless for the moment. Very annoying. Luckily I have Google home to control everything while this is hopefully getting fixed asap
same thing here, following
Iām also getting this, UK based on EU01 West shard if it matters!
