ok logged a ticket, i got a nice pre-canned response back
Hi Stuart,
Thanks for getting in touch.
At the moment the Netatmo isn’t an official “Works with SmartThings” device. As you are using a custom SmartApp to get this added on, it’s possible that recent changes to SmartThings haven’t been reflected. This would explain why it once worked but now doesn’t.
As it is a custom SmartApp, all we would be able to advise is to get in contact with the app developer to see if they are able to get it working again.
If you have any other questions or issues, please get back in touch.
Kind regards,
Thomas S
so i wrote back the following, hopefully it will be taken seriously (the table doesnt display correctly in this forum)
Thomas,
Thanks for the pre-canned response, however you are completely missing the point here. I am the app developer.
Forget about the fact it is a netatmo or the fact that this is a custom smartapp, this point is irrelevant. The point to be made here is that the section where I define the selection by device handler as highlighted below does not work on the IOS or Android Apps. This is a documented API feature
preferences {
section(“This Netatmo Base Station”) {
input name: “netatmo”, type: “device.netatmoBasestation”, title: “This Netatmo Base Station”
what I am trying to point out is that a documented feature to list devices by device handler and not by device capability which is documented under the official smartapps create smartapps documentation here http://docs.smartthings.com/en/latest/smartapp-developers-guide/preferences-and-settings.html under the following table, I have highlighted the following entry of your documentation
type
String - one of the names from the following table:
Name Comment
capability.capabilityName Prompts for all the devices that match the specified capability.
See the Preferences Reference column of the Capabilities Reference table for possible values.
device.deviceTypeName Prompts for all devices of the specified type.
bool A true or false value (value returned as a boolean).
boolean A “true” or “false” value (value returned as a string). It’s recommended that you use the “bool” input instead, since the simulator and mobile support for this type may not be consistent, and using “bool” will return you a boolean (instead of a string). The “boolean” input type may be removed in the near future.
decimal A floating point number, i.e. one that can contain a decimal point
email An email address
enum One of a set of possible values. Use the options element to define the possible values.
hub Prompts for the selection of a hub
icon Prompts for the selection of an icon image
number An integer number, i.e. one without decimal point
password A password string. The value is obscured in the UI and encrypted before storage
phone A phone number
time A time of day. The value will be stored as a string in the Java SimpleDateFormat (e.g., “2015-01-09T15:50:32.000-0600”)
text A text value
So telling me you don’t support this is complete rubbish, this is your API documentation, and a feature listed as working, works in the Smarthings IDE, but does not work in the IOS or Android Apps.
So please forward this onto the correct development team, it is nothing to do with the fact the device type is not officially supported, or the smart app is a custom one, it’s purely to do with the fact that your API’s listed functionality does not work as advertised on the mobile clients. The API is in fact supported? Correct?
Regards
Stuart Buchanan
