I too am using an aeotec multisensor for lux to trigger some lighting. The aeotec is under a covered patio on the nw side of the house so, while the readings are accurate for its location, it doesn’t necessarily serve the whole house too well.
My PWS is positioned much better to get accurate readings throughout the day. I see that WU is displaying illuminance measurements in watts/m2 from my PWS. I did a quick conversion from w/m2 to lux here:
The calculation is pretty simple, w/m2 * .0.249 for sunlight.
So I guess I don’t understand what the problem is for the Weather Tile app. Is it that WU API doesn’t let you query luminance data directly, it just gives you this condition list instead?
Is there a way to have this Device.station tile app display info from a local station from WU?
I don’t have a WX station of any kind but a neighbor up the road shows up on weather underground map and I can see his station info. I’d love to be able to have a weather tile(s) that show all local data just not my own (station).
Anyone know if this is possible to point the smartapp to an online source rather than a (personal) local device?
@RBoy - I would like to use this tile/data to drive webCoRE functions for my Hue lights. Basically, if the weather is “overcast” or “cloudy” then I want the lights to be different versus if it is sunny.
Do you know what the actual field is, and what the different options are (actual field data) that I can use in my piston to make this work?
RBoy
151
If you’re using the stock ST Weather Station you have a couple of options:
You can use the attribute weather and check for values like sunny, clear, cloud, fog, rain tstorms etc (the list goes on)
I’ve got this app installed and I like it but I’d really like to disable the ‘weather alert’ sms messages I get. Is there an easy way to do this and if so, how?
I’m okay with commenting out the lines of code that might be required to do so if someone could help me show which lines to look at.
I’ve got on my Hadashboard Smartweather Tile added as device under smarthings. Should I need any controller to get the API KEY I need to input in my code? If yes can you suggest me which device controller I can use? Type, model? great appreciate any advice.
Can anyone smarter than me figure out how to output in metric? It takes your local temp scale and will display the units accordingly (in my case, imperial), but I want an alternate DTH that shows the opposite.
i’d be fine with hardcoding metric values, or just showing the opposite of what the local hub uses.
i took a stab at it. seems to mostly work, and i’m able to add the temperature tile to ActionTiles which is all I really wanted. It takes values originally in imperial units and converts to metric. Not the other way around at the moment.
if you want AT to show their primary weather combo tile the name of the DH needs to have the Metric part removed. But their tile statically displays mph, even though this has converted to kph. does not touch the forecast long text
Has anyone had issues with weather tile no longer updating. I have gone into the app setting and changing refresh and it works for a few days and goes back to not working. The app is almost unusable at this point. Anyone else having this issue? Any other ideas on getting weather info on ST?
