So I set up the Virtual Weather Station so the program just knows to look at what ever virtual app I have configured as a device.
Sorry⊠I was wrong! I was thinking that we had integrated with weather devices. We have only talked about it. Sorry, I should have checkedâŠ
In the scheduler app, you just need to provide your zip code. We use a ST feature to grab weather information (which comes from Weather Underground). No need to create a virtual device.
See this for details⊠http://docs.smartthings.com/en/latest/ref-docs/smartapp-ref.html
If you, or someone close by, has a personal weather station and upload to Weather Underground, you can type in the station ID (âpws:XXXXXâ) instead of the zip code, and the app will use the data from your weather station. This is a standard SmartThings feature for weather zip codes.
Nice! I didnât catch onto that. Bonus feature!
so where in the code do you do that. I would like to start making changes so that i pull temp and wind data if possible
There are 3 functions in the timer app that determine if it wasWetYesterday
, isWet
(todayâs precipitation) or isStormy
(forecasted be wet tomorrow)
getWeatherFeature
is a SmartThings API that retrieves data from Weather Underground. I believe that wind and temps are available. Youâd have to checkout the documentation to figure out how to get to it. When we were putting the weather feature in, the Smart Things documentation was not great around this feature. We had to look at the Weather Undergroundâs API. If Iâm remembering right, the Smart Things API response closely mirrors the Weather Underground responseâs data structure. That was over a year ago, so the ST docs may be better now. (and my memory may be completely failing me)
Well I started the irrigation app for the first time this week since in New Mexico it is good weather. I had it set up to run every day. Until today I noticed is was not running so I had to run it by hand. I did a little troubleshooting and noticed that whenever I had the rain delay set that the program would not run. I still need to do a little more testing but I had it set for a weather station close to my house. I had it set to not run if it was less than .25 inches and had yesterday today and tomorrow set. We have not had any moisture for the last week and none scheduled till next week.So I am really not sure why it was not running. I am going to try to set it to just the zipcode to see if that works but is there anything else I need to check?
Thatâs how I run my setup (or ran last year - still cold here:) ). I would suspect the SmartThings scheduler. You can check in the IDE to see when last the scheduled task ran for the irrigation controller. You can click the new Update button next to the smart app in the IDE to try and kick start the app. If it is running correctly, you should see events in the phone app notification screen that says something like "skipping watering today due to precipitation for the times that you set your system to run.
The problem that I have with the log is the the smart sprinkler sends so many things to the log that trying to go back is almost impossible to go back an look at the log more than 12 hours it sends controller status for every station every 10 min
Turns out only zipcode works. Whenever you enter just a station any election for rain delay will not allow the schedule to kick off.
What did you type in for station id? It worked fine for me when I ran it before the winter.
KNMALBUQ301 this i what I used. Is it in the right format
it should be pws:KNMALBUQ301
Will give it a shot. Thanks
EDIT: Actually, this worked as @Dan999 described.
My recollection is someone posted they had a variant of the app that takes a PWS. I think itâs an easy fix that I just havenât got around to implementing.
Unfortunately I am on the road and probably wonât be able to take a look until this weekend. However I am interested in adding this feature. Also I will take a look at reducing the logging.
Were do you get the SmartThing ThingShield?
He has a few links on his instruction page that will show you where to get everything. I think I got mine on amazon
thanks. I would like to use a local station since I am up way higher then the zipcode and the weather could be a lot different âŠ10 degrees cooler and a big difference in the amount of rain.
Direct from DT:
I donât recall changing the code, and the version I use (2.92, dated 2014-06-16) has the zip code as a text field. It calls getWeatherFeature() which passes the request on to the WU API and they specifically mention the use of personal weather stations as a location option. As mentioned before, the location string must include âpws:â followed by the station ID.
http://docs.smartthings.com/en/latest/ref-docs/smartapp-ref.html?highlight=getweatherfeature
http://www.wunderground.com/weather/api/d/docs?d=data/index
I hope Iâm not disappointed come spring
