Being new to ST’s one of the first items I wanted to address was security and safety. I have a pre-wired smoke/CO2 detectors that are interconnected. Is there a solution to replace one so that if any go off I get a notification?
Nest has a detector that is hard wired and interconnected with more of it’s own kind. I’m not sure you could install it in concert with your other existing detectors while still preserving the interconnection or not.
PhilB. Thanks for the reply. I know Nest and others do within their own network, but want to replace all of my detectors. It would be nice to just replace one and get an alert. When I’m away I don’t care which alarm goes off, but that any of them have gone off.
You could try a Leeo.
ErnieG,
I may in the meantime, but I’d prefer to have something hardwired vs relying on hearing a noise. Its a trust thing.
Thanks!
The question of interconnect with a mix of smart and dumb detectors came up in a thread about Halo a while back.
If I remember the gist of the discussion, it was that pretty much any smoke detector manufacturer will guarantee that their interconnect function will work with devices of their own brand only. For smart and dumb detectors. Not sure why that isn’t standardized.
Mark,
Thanks! This is what I wanted to hear. My home is currently wired with First Alert SC07CN. It sounds like I can replace one with a CO501CN-3ST and be able to push that to ST.
Only way to find out is to try I guess.
Thanks!
Hmm, not sure if I’m understanding what you’re trying to do now.
That’s a battery powered smoke/CO detector. It has no interconnect function, but it can be set to announce the location of the alarm that is going off (from the speaker on the device itself).
https://www.amazon.com/First-Alert-SCO7CN-Battery-Operated-Combination/dp/B0002CWXZG
Do you mean SCO501CN-3ST? That’s also a battery-operated smoke/CO detector, although this one does have a wireless interconnect feature.
https://www.amazon.com/First-Alert-SCO501CN-3ST-Operated-Combination/dp/B000EVO7C2
So I’m confused by what you mean when you say your house is currently wired with SC07CN; that’s a battery-only device.
If you have several battery-operated detectors without interconnect (SC07CN), and you replace just one with a battery-only detector that has a wireless interconnect (SCO501CN-3ST), then what is it you’re hoping to accomplish?
Also just to be clear, the wireless interconnect on the SCO501CN-3ST does not mean it can connect to SmartThings or any other home automation hub.
The first alert zsmoke and zcombo work with SmartThings because they use z-wave, unlike the proprietary wireless protocol that connects a group of the SCO501CN-3ST devices.
Halo can be integrated with ST because it supports zigbee. I don’t have a nest protect, but I assume any integration with ST must be cloud-to-cloud.
Had the wrong part numbers in front of me. The correct ones are SC7010B and 9120B. They are hardwired and interconnected. My question is do they make a version that is hardwired that is zwave compatible? When any alarm is triggered the others go off via the interconnect wire. I wanted to get a notification if away from the house.
Unfortunately no. The only z-wave models are battery powered.
You can get a halo and connect it physically to your other detectors. Halo can then connect wirelessly to your ST hub.
You should check their website or that forum thread I linked to above, about how well the wired interconnect with non-halo devices has been working.
I don’t have the interconnect wires in my apartment, so my halo has no other detectors to connect to.
But I do like the way it can connect wirelessly.
And the z-wave detectors made by first alert are good with ST too.
Thanks for all of the information. I’ll check out the halo.
If you’re mainly interested in a device that will tell you remotely that one of your smoke detectors is going off, you could look into the smoke (and CO) relays made by kidde and first alert. People have had success connecting them to z-wave contact sensors that can accept external inputs.
This can be assigned a device handler so that it would basically tell you that something went off on your interconnect wire. It couldn’t be more specific than that, but I’m not sure if you can get that now with the wire.
I use Leeo Leeo Smart Alert Smoke/CO - $29.15 to connect make my hardwired smoke detctors integrate with Smartthings via IFTTT.
I used the [RELEASE] Universal Virtual Device Type and Translator to create a switch with the Smoke attribute. When Leeo detects an alarm, it triggers IFTTT to turn my Smartthings “Smoke Switch”. Smartthings treats it as a smoke device and will integrate it with Smart Home Monitor.
Leeo is hands down the best option here. I’ve had two Leeo’s, as well as my Insteon connected First Alerts. The Leeo’s ALWAYS alert me faster than the Insteon, or my connection via IFTTT/Insteon to Smart Things.
I tested Heiman Smoke Detector z-wave plus 868.42MHz (HS1SA-Z) and works good, but only smoke detector, not CO.
I made a mini post here: Heiman Smoke Detector z-wave plus 868.42MHz (HS1SA-Z)
can you tell me the device handler you use
Is there a smoke/CO detector that also has a temperature sensor?
It is a smoke detector type : Heiman HS1SA-Z
I use “Z-Wave Smoke Alarm”
I have the Halo+ and it has Smoke/CO/Temp/Humidity and NOAA radio. Not the cheapest HW smoke detector but I’ve put it through it’s paces (I install life safety systems for a living) and it works as good as any smoke detector I’ve ever dealt with. Did take me 2 tries to get it on my WiFi though.
