bmelika
(Bassem Melika)
May 20, 2018, 10:57pm
1
Hi guys,
I need to know if there is any smart lock out there that can be installed on a 7 cm (2 3/4) door thick (Euro profile/Cylindrical) and be compatible with a US smartthings hub.
Below is the door:
https://www.photobox.co.uk/my/photo/full?photo_id=500789581431
Kind regards,
Bassem Melika.
You don’t need to post duplicate threads. I have responded to you in your original thread:
Hi there,
I have samsung smartthings hub (US version) and I have ordered a Yale smart lock YRD 226 (US zwave) that is coming on its way. However, I just found out that my door thickness is about 7 cm (2 3/4) and the maximum thickness YRD 226 is compatible with is 2 1/4. So can I have any work around for this?
I live in Egypt and our door locks here in Egypt is Euro profile (Cylinderical) however, I was going to open a new key hole in my home door above the existing one to be able to install YRD 226. So will I face any issue due to the door thickness mentioned.
Appreciate your support. Hope there is any workaround available to get it installed. If not, can you please advise for a zigbee or zwave smart lock that can be installed on a 7 cm door thick? I need it a US z wave to be compatible…
