I’m in the very slow process of changing over to v2. I’ve noticed that you can’t seem to limit a motion triggered light to turn on ONLY when it is dark… I had that scenario setup in v1 and it worked great. It often doesn’t make any sense to have the lights turn on in the daylight. However, I want to make sure that I have local processing in v2 for these so can’t use the third party one I was using in v1.
Is adding illumination to the motion scenario in the plan somewhere?
I also noticed that you can’t set a dimmer value, either.
