Smart Lightning not mirroring color temperature
Hi,
I’ve setup Smart Lightning to mirror some Hue-Bulbs (all connected to the Hue-Bridge) in the new app.
The mirroring of the on/off-Behaviour and dimming level works perfectly, but for some reason changes in the color temperature are not mirrored and stay local to the bulb that should be mirrored.
Is this a known limitation?
Thanks,
Thorsten
It is a missing feature. You can try to report it to support.
Hm, thank you very much. I guess I will report this to support and will see what’s happening.
Just had same issue, seems obvious. I had to create scenes but not perfect as can’t toggle a scene on/off on my button so have to do 1 on dim 2700k, 2 bright 4000k, 3 long press individually toggle
