I’m new to home automation and in need of some help. I have a smart things v 3 hub and several Treat life Wi-Fi switches that connect through the smart life app.
What I want to do is control the treat life switch for the laundry Room with a Smart things motion sensor.
I have created virtual switches in the smart things hub and connected them via IFTTT with the smart life switches. I created four applets for each switch to turn them on and off, smartthings to smart life and smart life to smart things. I then created an automation in smartthings between the motion sensor and virtual switch. Motion detected triggers the light switch on. Here is where I get stuck. I can not get the motion sensor to trigger the light to turn off after X seconds of no motion. Is there anyway to do this?
