I’ve tried creating a custom rule in Smart Home Monitor that turns on a couple lights to 80% when triggered by an open door sensor. Currently opening the door does issue commands to turn the lights “on” (assuming they aren’t already), but never seems to issue any Light Level commands to 80% as the rule is configured for. I’ve tried recreating things several times and have been monitoring things in the developer logs. Level events never come through.
Has anyone else noticed this, or are Light Levels working for some of you in custom SHM rules?
ST is having some issues that are being worked on. Some things are getting fixed before others.
Not really sure what problem you are having however myself and others are having great success using a custom SmartApp created by @bravenel called Rule Machine.
I use Smart Lighting also, but I was talking about Smart Home Monitor. When you are in Smart Home Monitor and choose “Configure” from the menu, there is an option for “Custom” below Security, Smoke, and Leaks. Outside of setting levels, it was working fine for me.
