Smart devices interferes with my indoor cameras?
#1
i have 4 Logitech Alert cameras inside the house that were working flawlessly prior to me starting my Home automation project.
since i will be off work for a week, i decided to turn-off my camera server. since id be turning off electrical lines from the breaker box when i started installing GE 12722, GE 12729, GE 26931 switches and a number of Cree connected bulbs. the installation of bulbs and switches went fine and we are happy with it.
now that i am back at work and decide to fire-up the camera server, i’ve noticed only one of the four cameras come on. the other 3 cameras seem to turn on intermittently. this behavior of these cameras has not happened before until i installed the switches and bulbs.
so, did the zigbee and z wave,z wave plus signals affect the signals my Logitech Alert cameras require to function properly as these cameras are POE’s?
#2
I had an issue similar to this, I had to move my wireless channel away from what the zigbee channel was on.
#3
how do i do that?
#4
See if this link would help.
(David Hamilton) #5
So if the cameras are POE. I assume you are powering them W/ POE so why use wireless at all? The data cable can carry the power and the data at the same time.
#6
Am not sure i understand your question…
(Don) #7
When I Googled Logitech Alert camera, and read the description. It says the camera plugs into a wall power adapter which acts as a powerline network over the house wiring.
Is this what you have? If so possibly the errant cameras did not reconnect to the powerlines adapter that plugs into your network.
Possibly a power cycle of the base hub. Then each camera 1 at a time so they have time to reconnect?
Just shot gunning here.
#8
I don’t think they have a base hub… will have to double check. have had them for the last 5 years…
they may have a mother unit(that may equate as the hub) that is directly connected from the router then to the wall outlet… worth a shot…
thanks.
(Don) #9
Yeah that’s what I meant, if they use the power wires to connect a reboot might work?
