Slider Dimmer
Is there a device out there that uses a slider for dimmer control but is z wave. I want to replace a dimmer for my bathroom with Z wave but don’t really like the push and hold dimming. It’s nice to be able to just slide the switch on and stop it where you want the dimming. This turns into muscle memory and can be done as I’m passing the switch.
This could be accomplished by wiring around the Z wave module but then I would not have off control if the dimmer switch was still on.
I have the same question, don’t want a multi-button or push and hold dimmer. I will buy at least 6 dimmer switches once there is a slider version, but I can’t find one.
