Siren with custom notifications?
Is there a siren where I can customize the alarm / notification? Thanks!
I use the Aeotec Siren 6, you can check out the technical specs here to see if it meets your needs.
Thank you so much!
https://www.amazon.com/dp/B01M1NLPKZ?asc_item-id=amzn1.ideas.3BD6NOWXEK9QN&linkCode=sl1&tag=oddjobs4bud-20&linkId=3b93e9dc20fc59d8122b2e08b91dff90&language=en_US&ref_=as_li_ss_tl
I had seen this, but I don’t believe you can customize the message. Do you have experience with it? The price is definitely right.
Do you mean sending a customised message like this?
No, I haven’t done it yet, I’m waiting for Amazon to deliver the siren to me to test as demonstrated in the video.
I have a chicken coop with a walk in run. I would like the siren to announce that the run door is open, every 5 seconds, until it closed. To make sure no one leaves it opened.
I have had this device or a similar one for about a year.
Paired with a Tuya hub you get 18 different ring tones in the Tuya App.
Paired with a SmartThings hub you get 1 ring tone.
Paired with a Tuya Matter Bridge you get 1 Matter Switch imported into SmartThings. Which gets you one ringtone in ST. To get it to work with STHM you need to link it with a virtual Alarm. You still get all 18 ring tones in the Tuya app.
Mine is currently paired with a Tuya Matter Bridge.
In SmartThings I use the imported Matter Switch for my intrusion alarm.
In the Tuya app I created several Tap-to-Run automations for fire alarm, water leak alarm, and alarms off. The Tap-to-Run automations also get imported into SmartThings as Matter switches but with no state (basically buttons that look like switches). I link these with virtual Alarms in ST so they can be used in STHM.
