Good morning. Someone know how to reset to re-pair the samsung siren? I had to change the hub and everything is fine except that it does not go into pairing mode. Thanks in advance.
Do you have the model number?
Yes. SKU F-SRN-ZB-VF-1
Hi,
I have de same problem!
How can I reset the siren / enter pairing mode, to pair with other hub.
Thanks in Advance.
Hi Jorge. For the model of siren listed in this thread, you can reset it and put it into pairing mode by holding down the button on the siren while plugging it in. You will want to keep holding it for a second or two after plugging it in until you see the LED on the button turn off, then release the button.
If done correctly you should see the LED blink 3 times every few seconds to indicate it is in pairing mode.
Thank you. It works!
Could you confirm, that this device works as a zigbee repeater because it is constantly on power?
