I’m working a device type and I’ve been using the simulator without any issues for the past 2 weeks then, out of the blue, by the end of last week, it stopped working.
I hit “Set Location”, then pick my device and hit “Install”. I see a small loading icon and then the whole panel goes blank. I tried on Chrome and IE. I tried in an incognito window… nothing works.
Are you using physical devices? There was a bug that would cause this issue when selecting certain physical devices. The fix has been coded, but I’m not sure if it’s been released yet.
By physical device, I meant anything that wasn’t a virtual device. Given that it behaves the same if you choose a virtual device, this may be a different issue. If you’re familiar with the javascript console it Chrome, can you keep it open while going through the install and let me know if there are any errors?
We know there are a number of issues with the simulator and we’re starting to go through our backlog to get the worst offenders fixed prior to a complete rebuild.
The multi tile issue is one we’ve taken steps to fix. The fix will be going out in the next couple of deploys. There are probably more issues we’ll need to fix and we’re working on them now as we find them. I’ll follow up here as fixes go out to see if we’ve corrected your specific issue.
Looks like my changes didn’t get into the release going out today. Due to Thanksgiving, it looks like the next release isn’t scheduled until next week.
